Home > Technical > Any of you have and use your ADaptive cruise control? |
TDV8_AutoB Member Since: 03 Jul 2015 Location: Berkshire Posts: 35 |
Check on the instrument menu - there should also be a Forward Alert setting configurable (it uses the same ACC) - assuming you've got this, you've got ACC but perhaps a previous owner change the steering wheel for some reason ??. Assuming it's not there, then you've not got it (and maybe a previous owner installed the ACC on the front for some reason/bumper replace ??)
Sun Jul 05 2015 6:16pm |
Chillbrazil Member Since: 31 May 2015 Location: Portsmouth Posts: 85 |
Use it often, also use the forward alert which beeps if you do not appear to be braking in time on just normal driving. It was standard on the AB and HSE Luxury and an option on others. As you correctly noted it should have two buttons on the left side of the steering wheel.
Sun Jul 05 2015 6:23pm |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
Ile have a look on the way to work today.
Mon Jul 06 2015 4:22am |
rhenus132 Member Since: 13 Jun 2015 Location: Kaltenengers Posts: 34 |
can you post a pic how the buttons look like?
Thu Jul 09 2015 3:48pm |
