Home > Maintenance & Modifications > New front discs needed? Maybe?
Morgi27
Hi guys
Just checked my front discs and measured them with caliper measuring tool and are 30mm thick
I know should be changed at 27 mm and also pads aswell with new discs
Just wondered should I change the discs now has getting near to limit of 27 mm?? Do have quite a lip on the edge also
Back are fine has was changed at service before I had car and are 25mm still,limit 17mm if I'm right
Post #462095 Sun May 17 2015 10:36am
garrycol
Australia
Firstly unless there is an issue you do not need to replace disks when replacing pads - I am on my second set of pads on original disks.
At 30mm your disks are barely worn (I think they are 30mm when new) so unless there are deep gouges or they are warped there is no need to replace the disks. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #462096 Sun May 17 2015 11:05am
Morgi27
I know don't have to replace discs when replace pads but when replace discs should replace the pads aswell is what ive always known?!
I don't quite understand that then if new discs are 30mm to start off with mine are on 30mm now and definately not new has they have a lip on them from wear
Anybody else got any views? What is the thickness of new front discs ???
Post #462108 Sun May 17 2015 2:42pm
Bodsy
Site Sponsor
New front disks are 30mm, they have a wear limit of 27mm. You need to measure the 'working' part of the disk with a gauge. If they have a thick lip around the edge and are heading towards the 27mm thickness, then get them replaced. Additionally, if they are excessively corroded, it will be blocking all of the cooling fins, so will be starting to become less efficient, so may well be worthwhile changing.
The rear disks are 20mm thickness new and have a wear limit of 17mm.
When changing disks, it is always recommended to change the pads, otherwise any uneven wear you had on old disks, will be transferred to the new ones from the partially worn pads. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #462128 Sun May 17 2015 7:27pm
Morgi27
Yeah they do have a lip on them,and look to me to rather rusty around edges too so I'll get them changed
Post #462132 Sun May 17 2015 8:24pm
Bodsy
Site Sponsor
Brake bible is on my link below if want to tackle it yourself. Thumbs Up Thumbs Up Bodsys Brake Bible
See it HERE
Post #462136 Sun May 17 2015 8:58pm
Morgi27
Yep ive read all on your brake bible about it and done them before
On other cars so will be tackling it myself has made sure ive
Got Right sockets etc
Any advice on removing the brake
Caliper bracket has I know these can be very hard to shift the nuts! Breaker
Bar and plenty of wd40?
Post #462139 Sun May 17 2015 9:13pm
Bodsy
Site Sponsor
Just a breaker bar and bi hex socket will be fine Thumbs Up Bodsys Brake Bible
See it HERE
Post #462140 Sun May 17 2015 9:24pm
