Home > General > I've gone and done it! bought a 2011 RR tdv6 autobio but nig
jprr
2011 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
So I've take the dive and got me one of these its got a full lr history and last full service was done 5k miles ago. But the niggles...
1. Noisy and heavy steering now and again mostly at slow speeds
2. Rear offside passenger door doesn't lock with key
3. Unclipped and missing back rubbers for both front doors
4. Wiring exposed can see fuse box should there be a cover of sort?
These are the things for now! Any help or advice or common symptoms cures would be greatful.
Thanks
Jig Smile
Post #457777 Tue Mar 31 2015 12:06pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Hi nice car but the niggles you have need sorting really Shocked DO YOU HAVE A WARRANTY.
1. Noisy and heavy steering ??? s teering should be silent and easy to turn. I can turn mine with my little finger no problems. Thumbs Up
2. Door won't lock ??? Get that sorted ASAP.
3. Rubbers missing from doors what rubbers are you talking about
4. Wiring exposed from fuse box ??? There should be no wiring exposed all wiring inside the glovebox from the fuse box is neat and tidy. Do you have the corner trim missing in the footwell ??? If not someone has been tampering.
Post #457799 Tue Mar 31 2015 4:26pm
jprr
Hi
Thanks for the reply martin. Let me elaborate some more..
1. The steering is more heavy then noisy and tends to be at low speeds or cornering it tends to get heavy.
2. I'll get this fixed think must be a motor or latch issue hoping it won't be too expensive.
3. I'll ad d pics
4. Its underneath by he drivers seat can see wiring and fuse box shouldn't this be covered in some way??
Thanks
Jig
Post #457813 Tue Mar 31 2015 6:00pm
ABSport
Fuse box is the passenger side. As said earlier steering should be light so be woth getting checked out.
Post #457822 Tue Mar 31 2015 6:52pm
Steering is speed sensitive and controlled by the air suspension module that lives on the driver's side a-pillar. It's accessed by way of the driver's footwell. Perhaps items 1 and 4 are in some way linked? 2012 SDV6 - it's missing a couple of cylinders
Post #457826 Tue Mar 31 2015 8:11pm
jprr
OK sorry for confusion...
So for 4. its the fuse box/wiring underneath the seat which is exposed when you forward the seat all the way.
Latch issue has been fixed.
So only outstanding issue is with the heavy steering/loss of power to steering which is still affecting the car intermittently.
Any ideas or things I should check for?
Thanks
Post #459858 Mon Apr 20 2015 12:25pm
