Home > Maintenance & Modifications > 2012 RRS TDV6 Service Indicator Reset
JK07
Australia 2012 Range Rover Sport 3.0 TDV6 SE Fuji White
Hi Guys
what is the procedure for resetting the service indicator msg? It came bit early not sure why but I am gona do full service myself, Oil, Oil Filter, Air Filter and may be Fuel Filter also.
Any help would be appreciate. cheers
Post #456002 Mon Mar 16 2015 3:04am
Can i ask, why are you doing the service yourself ? Obviously cheaper short term.
Post #456040 Mon Mar 16 2015 11:23am
JK07
Its out of warranty now and what dealer charges is just ridiclous. I like working on my cars and want to do things correctly. Always use genuine oil and filters etc and saves me heaps of coins, and gives me peace of mind that all done is correct.
Now can someone please let me know if there is a procedure to reset or is there any scan tool available which i can use and keep for future issues.
Post #456041 Mon Mar 16 2015 11:35am
Lost for Words
To my knowledge, there's no other method for your vehicle.
In terms of diagnostic tools, you'll likely be looking at either a GAP IID (the Bluetooth version is best) or BBS Nanocom. There's plenty of information and comparisons available but you may find more info on the D3 site. Thumbs Up Visiting from DISCO3.CO.UK
Post #456044 Mon Mar 16 2015 11:51am
Robbie
Location: Waiting for my old avatar to be allowed back... we miss her!
From MY08 the following works on the D3. I am told that it work on later model RRS too, but I use an IIDTool as my patience is limited:
Switch ignition off.
Press and hold the mileage reset button.
Turn ignition key to position ll.
The message " service " will flash for 5 seconds and then be permanently displayed.
Note:if the service interval indicator function is not programmed the normal odometer and trip information will be displayed.
Release the mileage reset button within 10 seconds to display " oil ".
To reset " oil " service indicator : within 10 seconds press and hold the mileage reset button for at least 6 seconds. the message " reset " will be displayed for 5 seconds followed by " inspect ".
To bypass " oil " service indicator resetting: within 10 seconds press and hold the mileage reset button for less than 5 seconds. the message " inspect " is now displayed.
To exit resetting : do not press the mileage reset button within 10 seconds.
To reset " inspect " service indicator : within 10 seconds press and hold the mileage reset button for at least 6 seconds. the message " reset " will be displayed for 5 seconds followed by " date ".
To bypass " inspect " service indicator resetting: within 10 seconds press and hold the mileage reset button for less than 5 seconds. the message " date " is now displayed.
To reset " date " service indicator : within 10 seconds press and hold the mileage reset button for at least 6 seconds. the message " reset " will be displayed for 5 seconds followed by " end ".
To bypass " date " service indicator resetting: within 10 seconds press and hold the mileage reset button for less than 5 seconds. the message " end " is now displayed.
To repeat resetting : within 10 seconds press and hold the mileage reset button for less than 5 seconds.
After 10 seconds : the service type and time/distance to next service are displayed.
Thumbs Up Land Rover - Turning Drivers into Mechanics Since 1948
How To - Battery & Quiescent Current Drain Testing
Free Fault Code Reading For Established Members:
Defender, FL2, D3, D4, Evoque, RRS & FFRR
Post #456047 Mon Mar 16 2015 1:08pm
Lost for Words
That's an interesting thought that LR have continued a useful feature for once. Out of curiosity more than anything, I'd like to know for sure if that does indeed work on later vehicles as I'd assumed that from 10MY on it wouldn't as I could find no mention of it still working; I suppose they aren't old enough yet for that many people to be self servicing? Visiting from DISCO3.CO.UK
Post #456053 Mon Mar 16 2015 2:57pm
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
I tried all that on my 10MY HSE RRS. Does not work ( no reset Buttons) As i understand it has to be done on diagnostic. Main Dealer Technition did mine as a favour,whilst sorting out otherr problems,on diognostic itisme
Post #456056 Mon Mar 16 2015 3:12pm
JK07
We have press button start so ignition key dance will not work.
Is there any scanner tool which you guys are using? I searched but cant find anything relevant.
Post #456155 Mon Mar 16 2015 11:25pm
Bodsy
Site Sponsor
You are best off with an IID tool from Gap diagnostics. Sold in the uk through britpart dealers. I know britpart normally means Censored , but not in this case. A very comprehensive solution for all fault code reading, resetting and calibration/service activities. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #456158 Tue Mar 17 2015 12:07am
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
I use a IID tool on mine purchased from Island 4X4 in the UK. I got the non Bluetooth version as its cheaper and does the same functions. (Other than live readings I believe)
Regards
Barry 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #456166 Tue Mar 17 2015 8:16am
Robbie
Whilst the original IIDTool can access the same live data as the Bluetooth version it does do a much better job of it. For some diagnostics you need the ability to display multiple lines of data, or even graph them over time. This is where the BT version come into its own. It is also a lot easier and quicker to use too.
The BT version also has more memory and contains profiles for multiple models, so it can read fault codes and live data on all the supported vehicles. The extra connectivity means you can export fault codes, recoded log files and take snapshots.
It is an impressive bit of kit.
Post #456172 Tue Mar 17 2015 9:14am
Barryp
Thanks Robbie,
For me service reset and clearing error codes were my main requirement, anything more and off to our local LR independent expert. Depends on your requirements and level of expertise I guess.
EDIT: Also used for battery BMS reset after battery change. (Mobile LR Australia use Allianz and they replaced the battery OK but couldn't do the BMS reset as they didn't have an LR computer on the service van!)
Regards
Post #456236 Tue Mar 17 2015 7:28pm
itsmeagain
I bought the IID tool myself after seeing it used, well worth the investment tbh. I activated my timed climate, tow bar electrics and few other useful things. Plus you can sell it when you sell the car at a later date. Resetting the service indicator is easy too. Current 2010 Range Rover Sport HSE with the usual toys: timed climate, Rosen headrest screens, tow bar with twin electrics, Blackvue HD cam
2008 Seat Leon K1
2012 Audi A1 2.0litre Black Edition TDI
2004 Audi A4 convertible
2004 Audi A2 TDI
Post #456297 Wed Mar 18 2015 7:57am
JK07
Thanks Guys that's really helpful.
Where is the best place I can purchase this online?
Post #456992 Tue Mar 24 2015 3:12am
Barryp
As above in my post, Island 4X4 in the UK I found was the best and cheapest source from Australia.
Regards
Post #456993 Tue Mar 24 2015 4:32am
