![]() | Home > Faults & Fixes > Suspension fault C1A20-64 - how to fix |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Very clever. Looks like a well engineered solution and should last longer than OEM. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
gruodiz Member Since: 27 Nov 2011 Location: Klaipeda Posts: 63 ![]() ![]() |
Thanks |
jmcvs Member Since: 26 May 2014 Location: Glasgow Posts: 173 ![]() ![]() ![]() |
Excellent write up and very nice bit of kit |
Brio Member Since: 22 Apr 2011 Location: South Shields Posts: 3 ![]() ![]() ![]() |
I had already overhauled the compressor but still the dreaded light came up. I then read your solution and checked the cap with soapy water and low and behold there is a fine crack between the two outlet threaded holes!
Received the new cap, cost £35 and came in 5 days. Its machined tough plastic, fitted this afternoon, took about 45 minutes without removing the compressor, did it in place.
danielgurney Member Since: 13 Apr 2015 Location: rugby Posts: 8 ![]() ![]() |
Hi do you have any more of these it won't let me pm as new member |
Hi, if you make a total 3 replies you will be able to pm him. |
wings21660 Member Since: 11 Feb 2015 Location: Gretna Posts: 65 ![]() ![]() ![]() |
Been in touch with Ignas he's putting one in the post for £35, & printed off his description on how to to the job.Showed it to my mechanic who said it was a clever bit of kit.Hope it get's rid of the annoying light on the dash, will update when i've had the job done. |
Miller Member Since: 05 May 2015 Location: Trowbridge Posts: 8 ![]() ![]() ![]() |
Suspension failure light came on today on 2006 tdv6 70,000 only had it a week |
Hi Miller mine was like that at the start but gradually got worse, so I came on this brilliant forum site & found the remedy. I got in touch with a Guy called Ignas who is on here sent him the payment through paypal & he sent me the part's job done |
Cheers wings It has not been back on all weekend coverd about 100 miles but most short journeys , think I may just order the part and do it one less thing to worry about |
well got the car back on wednesday after the mechanic fitted the new parts and hey presto there was a hair line crack in the compressor cover. so on went the new one good news no more orange light on the dash. Thanks Ignas for a great bit of kit well worth the £35 and coming all the way from Lithuania. |
Benidorm Mick Member Since: 27 May 2010 Location: Wiltshire Posts: 102 ![]() ![]() |
Hi all and especially gruodiz. I had the light and warning for a couple of weeks. Now suspension has dropped onto the stoppers and won't raise. Compressor is trying but car won't raise... Question - Is this indicative of the hairline crack scenario?? Help much appreciated |
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 241 ![]() ![]() ![]() |
Great wright up and looks like a nice bit of kit for an upgrade.
