Home > Technical > Help, I'ts gone potty !!! |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Hi Folks, drove the beast home last night , parked it locked it , great. Opened up this morning and started her up ! O dear me !! Hazzards flashing, Hill descent fault, Gearbox fault, suspension fault, the list is endless. I locked her back up and tried a few mins later and only half the faults there, done the same again, all gone and fine now. On the initial start up I had a zug-zug-zug instead of a zig-zig-zig is my battery getting tired, please help with any advice 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sun Jan 18 2015 1:04pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Have you checked your battery and alternator voltages?
Sun Jan 18 2015 1:31pm |
Battery is first place to start, then check the volts from the alternator when running. Bodsys Brake Bible
Sun Jan 18 2015 1:37pm |
Hi , thanks for the reply, I have 13.8 across the battery on tickover, so unsure on this one. When you say check under the wheel arches (to sound thick) which one, and what am I looking for ?? 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Cheers Bodsy, had similar on my D3 and it was the lead box that was on the blink. I'm sure this weather will sort a few out, 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sun Jan 18 2015 1:40pm |
13.8 sounds a little low for this time of year but shouldn't directly cause a problem.
Sun Jan 18 2015 2:01pm |
Fish Member Since: 29 Jan 2014 Location: Glasgow Posts: 60 |
Mine is doing the same, sometimes right at start up and other times when driving, also going into limp mode. I have to take the key out and let it go to sleep to reset it, this works most of the time.
Sun Jan 18 2015 2:15pm |
Spot on my friend, it's being a good boy at the moment or should I say today, standing charge was reading 12.2 v , hope this makes sense if I've understood your question correctly 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Forgot to say when mine goes crazy it is hazards on door locks opening and closing also noticed the oil temp gauge going up to max as well as the HDC, suspension fault, transmission fault, special programs not available basically everything going and if the engine is running and I switch it off it will not let me start it again until it has reset.
Sun Jan 18 2015 2:21pm |
Thanks for the reply, I've noticed one thing in your post which leads me to water ingress in my rear light cluster, I have this, could this be the problem... 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sun Jan 18 2015 2:22pm |
Are we sharing the same RRS 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sun Jan 18 2015 2:24pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
Have you checked the earth connections? There are several and a dodgy connections might cause weird behaviour. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sun Jan 18 2015 2:27pm |
Could potentially be the issue (brake bulbs, blown or otherwise, often cause issues). 12.2v is OK but a little low. Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Sun Jan 18 2015 2:35pm |
The only earth I checked was the connection to the battery when I had the battery out checking the plug connection under it, but I will follow the cables and check all for tightness when I get home. Thanks for the tip 2.7 HSE, Audi A6 Exec, Honda Accord Exec, Volvo 440, Volvo 360 |
Sun Jan 18 2015 3:07pm |
