Home > Technical > weird stiffness in turning since the cold weather? |
I'd check the lower steering column first. Takes about 1/2 hour to change and replacement is about £70istr. The joint starts to seize up after a while. Try wd40 on it first, if it makes it easier, then that's the problem. Bodsys Brake Bible
Tue Jan 06 2015 6:03pm |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 |
That's awesome news. I'll go try this - any links to doing this?
Wed Jan 07 2015 9:58pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
http://www.disco3.co.uk/forum/topic56798.h...ring+shaft 2012 SDV6 - it's missing a couple of cylinders
Wed Jan 07 2015 10:57pm |
monty19 Member Since: 12 Mar 2014 Location: boro Posts: 323 |
mines started doing this also, wheres the best place to get this from |
Thu Jan 08 2015 2:32am |
I'm impressed! Thanks man. Job the night. |
Thu Jan 08 2015 4:27pm |
