Home > Technical > Possible blown turbo |
If you are lucky, which is very rare owning one of these motors when something goes wrong It could be a split intercooler pipe Worst case scenario, blown turbo as you suspect. Hope you have a rock solid warranty. |
Fri Dec 12 2014 8:15am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Sounds just like when mine blew the turbo. Pulled out of a junction and suddenly no performance at all. Smoke from left exhaust (later from both) and the smoke is unpleasantly smelly.
Fri Dec 12 2014 9:10am |
Flatteraxe Member Since: 23 Apr 2014 Location: Leicester Posts: 43 |
No warranty at all
Fri Dec 12 2014 1:34pm |
The only way the air filter could get oil on it from a turbo failure is if the turbo blew oil back against the incoming air flow which seems unlikely as the pipes' routes are quite convoluted. Can't see how else it would get there.
Fri Dec 12 2014 3:29pm |
Car is with a garage that specialises in 4x4's. The weld on the intercooler itself has split. He took off the air filter in front of me which was covered in oil and some has gotten into the engine. Engine seems to idle fine.
Fri Dec 12 2014 3:49pm |
I still don't see how oil got in to the air filter, especially in quantities you're suggesting. Something doesn't add up for me. 2012 SDV6 - it's missing a couple of cylinders
Fri Dec 12 2014 5:37pm |
Perhaps Disco Mikey can shed some light on this issue. |
Sat Dec 13 2014 1:34pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
How much oil are we talking? A coating of oil, or dripping wet?
Sat Dec 13 2014 8:54pm |
Firstly, thanks for everyones input.
Sun Dec 14 2014 2:07pm |
Sorry to hear about this. It would be useful to know what the mileage is now and what it was at each service stamp in the book and whether the services were done by an official LR dealership or a specialist.
Sun Dec 14 2014 2:27pm |
It was always serviced on time, all with the main dealer apart from 2 at a specialist.
Sun Dec 14 2014 2:54pm |
Just had a thought. Whilst replacing the turbos, could the garage also blank off the EGR valves? Would there be much more work involved and is there any risks involved in doing this? |
Sun Dec 14 2014 4:44pm |
Tend to agree with the more frequent oil change but as you say: if it was the intercooler letting go that started a chain of events culminating in turbo failure then wouldn't have helped. Unless of course the turbo seals went first and the pressure of oil filling the induction side split the intercooler.
Sun Dec 14 2014 5:50pm |
They can be blanked by Alive Tuning, in conjunction with a software modification |
Sun Dec 14 2014 6:45pm |
