Home > Technical > Battery Charger recommendations...
kman
Hi guys,
My MY2007 RRS TDV8 battery is dead, the car hasn't been used for a few months now (parked in access mode) and need to get it up and running again - can anyone recommend a good charger that can charge a battery from discharged back up to full? Or do I need to seek another solution - car has no lights etc coming on.
Thanks
Post #444512 Sat Dec 06 2014 2:54pm
Rainbow
2013 Range Rover Sport SDV6 HSE Fuji White
I use a CTEK MXS 5.0. It is a smart charger and can deal with deep discharged batteries. For keeping batteries charged up while the car is parked up for extended periods, I have used it to trickle charge through a 12v accessory socket (needs to be one that is powered even when the ignition is off), on a Volvo not on a Sport yet. You need an accessory to do this though. I believe there is also an accessory sold through the forum that allows charging through the towbar electrics connector which would allow charging while the car was locked up.
Post #444514 Sat Dec 06 2014 4:04pm
Disco
As above the MSX 5 works well.
I got the Polar version that works at very low temps, as the name suggests.
Claims to terminals under the bonnet and it will close on thin cable without pinching.
Post #444524 Sat Dec 06 2014 6:28pm
kman
thanks, I've ordered the MSX5.
Post #444527 Sat Dec 06 2014 7:36pm
muddywheels
Milk Float Man
+1 for the ctek Bow down
I plug mine into the tow electric socket when it's parked in garage for extended periods and forget about it until I need it Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #444528 Sat Dec 06 2014 7:44pm
kman
Got my ctek charger today and plugged in. Connected it up but after a minute or so the charger goes into energy saver mode - I don't think its charging? I can't see what I've done wrong in connecting the battery terminals up. Admittedly I have an issue in that I can't open up the bonnet fully (due to a shelf) but I can open enough to see where I'm plugging the clips into.
Any suggestions?
Post #444678 Mon Dec 08 2014 6:00pm
Disco
Make sure you have the correct mode selected on the charger itself.
Post #444684 Mon Dec 08 2014 6:10pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Yes. Just had the same problem. The c tek will not charge a totally flat battery. You need to get an ordinary charger on it first, or jump start it to get some juice into the battery. Once the battery has a little bit of power the c tek will work. I think it needs 1.5-2 volts for the c tek to recognise it.
Neil
Post #444686 Mon Dec 08 2014 6:12pm
muddywheels
Milk Float Man
Sorry not sure what energy saver mode is Confused
I set mode to normal and it goes through the steps until full then maintains battery Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #444687 Mon Dec 08 2014 6:13pm
Bladeboy
Power saving mode is when the green led flashes because it thinks its not connected to a battery- in this case because it's too flat
Post #444688 Mon Dec 08 2014 6:16pm
muddywheels
Milk Float Man
Just checked handbook and appears to need min 2v before it works Rolling Eyes Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #444690 Mon Dec 08 2014 6:17pm
kman
Thanks il try the jump start - do I need to fire up the Range's engine, or just wire up from the second car and leave that one running for a while?
When the ctek is powered on but doesn't recognise its connected to a battery it goes into this energy saver mode.
Post #444691 Mon Dec 08 2014 6:17pm
Bladeboy
I'd probably Fire it up and leave it for a bit. I put mine on an old halfords charger for a couple of hours and then put the c tek on in recondition mode and after three days it's gone through all its processes.
Good bits of kit when used regularly but no good for really dead batteries.
Post #444692 Mon Dec 08 2014 6:22pm
kman
Hi, need a little help as i'm now able to get this process done. So i connected up the battery to another car via jump leads and left the donor car running for a couple of minutes so far. Tried firing up the RRS, its tries a bit then fails (gets a transmission fault too). Im assuming its still the battery - so question -
if I leave the donor car hooked up with its engine running for a longer while will it charge the battery in the RRS until its ready to fire up? Or do I turn the engine off? Or is there a bigger issue?
Post #447953 Fri Jan 09 2015 4:15pm
kman
just a little update the jumo leads have done enough to get the ctek charger working so now thats running on a recondition. Once complete hopefully the car should be fine (fingers crossed!)
Post #447956 Fri Jan 09 2015 4:29pm
