Home > Technical > Autodipping mirrors |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
I'm guessing it will be similar mine, press the right hand button on the steering wheel, this will bring up a menu on the dashboard. Use the arrow buttons to navigate through the options and you will come to the reverse dip mirror option. Check or uncheck the box to make your choice. 2010 RRS, TDV8
Wed Aug 06 2014 10:51am |
Gavin Beecham Member Since: 14 Sep 2007 Location: essex Posts: 140 |
Car needs to be in reverse when you set the mirrors up. |
Wed Aug 06 2014 9:21pm |
snarum Member Since: 06 Aug 2014 Location: Oslo Posts: 5 |
My problem is that the auto dipping menu item is not present in the menu. Changing the mirrors while in reverse has no effect. I'm starting to think that since I have heated mirrors, but not memory seats, this feature is unavailable, but according to the specs all models should have auto dipping. My local garage had a look at it yesterday, but they didn't have a clue. |
Thu Aug 07 2014 4:43am |
peterk Member Since: 17 Nov 2014 Location: Blackpool Posts: 10 |
Mon Nov 17 2014 7:58am |
Yes, you're probably right. Even though the brochure says that all models have this... We had the dealer look at this, and we never got it to work. |
Mon Nov 17 2014 8:03am |
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 |
Yes, the reverse dip mirrors are only available with the memory seat pack. |
Mon Nov 17 2014 8:06am |
