Home > Technical > FUEL MPG
ADO5TIMES
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
FUEL MPG
Was having a conversation with local garage when having some work done recently, who are convinced you will get a better mpg from using higher grade petrol/diesel such as Shell, BP etc. as opposed to using supermarket fuel.
I have not put it to the test as yet, but does anyone agree with this statement??
Post #439013 Fri Oct 10 2014 6:35pm
monty19
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
I would agree with them, I run the s/c on shell fuel as I have with all my cars the biggest change in consumption and performance was my wrx Subaru , I'd say it makes a difference and the cost is not worth worrying about.
Post #439015 Fri Oct 10 2014 6:50pm
Disco_Mikey
Cheap supermarket fuels have killed my injectors Big Cry
Only gets Shell/BP diesel now, unless I am desperate
Post #439032 Fri Oct 10 2014 7:59pm
myfirstrrs
Oh yes. Shell for me but I'm sure BP would be as good. Since I've started looking into it I have even got my wife on it with her car.
Post #439037 Fri Oct 10 2014 8:15pm
ADO5TIMES
Thanks for the responses, and it looks like I will be going down this route from now on. Thumbs Up
Post #439078 Sat Oct 11 2014 9:43am
monty19
My 19 year terrano gets shell
fuel aswell Thumbs Up
Post #439084 Sat Oct 11 2014 12:59pm
rich_sargie
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Asdas finest and a drop of 2 stroke is as good as any fuel you can buy.....
The only reason to deviate from this would be if you had a dpf fitted.
The fuel is the same it is just the additive, now if it were petrol that is a completely diffrant kettle of fish,
As it's all about resisting detonation for more power less fuel.
Post #439094 Sat Oct 11 2014 4:12pm
Been running my sport on shell V Power from new. 21500 miles now, I wouldn't run it on anything else.
Edit to add, showing 31.5 mpg on the computer.
Post #439106 Sat Oct 11 2014 7:11pm
ravingmad
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Santorini Black
Only use Shell V Power or BP Ultimate. MY13.5 Autobiography, Santorini Black, Privacy Glass. Gone
Driving a milk float for now.
Post #439107 Sat Oct 11 2014 7:18pm
monty19
My s/c shows 21 mpg on a run using shell
Post #439111 Sat Oct 11 2014 8:50pm
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
When I first joined this forum I'd seen a lot of posts saying this. But in a lot of asking and researching I've found that the diesel we buy here in Northern Ireland is the same stuff in every pump. The only difference is the additives they mix in for each container.
So if you really want to get a better mpg use a third party fuel additive at every 50 litre fill. That way you are actually using a better mix than you find at the pump and you can buy the so called supermarket Censored .
At least this is true for northern Ireland. I'm not so sure about you boys.
but interested to find out. It seems the extra mpg comes directly from the fuel treatment. Not the affect it has on cleaning etc... I'd also be tempted to hear more on terraclean success stories.
Post #439337 Tue Oct 14 2014 12:48am
ADO5TIMES
Thats a very interesting post Designboy. I have no knowlegde of better or worse diesels in the Uk, only what I have been advised.
Hopefully some more replies will be posted from more knowlegeable members.
I filled up yesterday and didnt know whether to stick with Tesco or BP across the road. I went with Tesco this time as i had 10p per litre off and 2p per litre less than BP, and therefore saved myself £9.12 Thumbs Up on the 76 litres of diesel fill. Thats not to say i wouldnt change though if it was detrimental to the running of the car.
If what you say is correct I am more than happy to utilise an additive every time I fill up. What do you recommend Designboy for diesel?
Post #439353 Tue Oct 14 2014 9:26am
designboy
Millers seems to be the forum fav here mate. I use it exclusively on each fill. I've a v8 diesel and it gives me around 26mpg on normal runs and 31 on motorway.
http://www.amazon.co.uk/s/ref=nb_sb_noss?u...+treatment
Post #439366 Tue Oct 14 2014 1:45pm
^^^^ Judging by what it is used for, i don't see why people don't just use a premium fuel like V power +. It works out cheaper in the long run anyway. Confused
Post #439367 Tue Oct 14 2014 1:53pm
designboy
I'd be interested Andy in the real world costs to do both, It says that its treats 10x 50 litre fills, so that means it is basically £1 per fill of 50 litres.
I eat through roughly 50 litres per week in day to day running.
Quick maths:
£62.95 to fill 50 litres with the cheap stuff + £1 to treat
or
£67.50 to fill with the V power or equivalent fuel
That costs
52.1775 weeks per year at £64 = £3339.36
or
52.1775 weeks per year at £67.50 = £3521.98
I'd guess that the millers would do more than the v-power would as its more of a direct treatment. But it is a guess and I'm only going on hear say. My costs from: http://www.petrolprices.com/[/s]
Post #439369 Tue Oct 14 2014 2:38pm
