Home > Technical > 7 way bypass relay or just wire a bulb in?
RRS Daz
Now I've found out the range rover sport doesn't like caravans/trailers with led taillights!!
Got the new tin tent and wifey says why are the hazards flashing, I'd noticed the reversing aid hadn't tuned off.
So the solution is a 7 way bypass relay or fitting a normal bulb somewhere on the caravan/trailer.
Has anyone done either?
Does the 7 way bypass get wired into the carvan or the sport?
Is fitting a blue inline with an indicator going to work?
Thanks in advance Thumbs Up
Post #437131 Sat Sep 20 2014 8:07am
