Home > Technical > no power f.....k
scott1963
no power f.....k
Hi can anyone help.i have a rr sport 2.7tdv6.went into start it this morning just to move it a couple of feet.to do some work on the front discs,started no problem applied the hand brake got out the car then deciced to move it again.turned the key fired up then cut out.it was in N at the time.at the time I was starting the jeep through the open drivers window. so deciced to get into the jeep and start it up.started no problem.
but I only have limited rpm up to 3000.message came up.SUSPENTION LOWERING,HDC FAULT TRANSMITTION FAULT LTD GEARS AVALABLE,When these messages go away PARK BREAK FAULT comes up.the park break works ok as I tested it.
icons that came up are triangle with half moon arrow.anti stability car with two small arrows.and warning brake pads
help.
Post #433586 Mon Aug 18 2014 11:10am
A couple of possibilites spring to mind with this one. Its possible you battery is low on power, or you have a brake light bulb that has blown. I once had the same fault pop up on my dash after a long drive, switched it off, then restarted it and the faults cleared and never returned. Bow down Hope it is something as simple for you. Thumbs Up
Post #433590 Mon Aug 18 2014 11:18am
hunter
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Its probably reacting to you calling it a JEEP................................. Gone but not forgotten, 2005 RRS SC first edition, BMW 2010 Z4,TVR Tamora, TVR Cerb, MERC SL 55 AMG, E46 M3, Z4, Jag S type R, Skyline R33 GTR 640 bhp, Evo FQ 400, L322 RR, X5, Lotus Esprit V8 twin turbo, Lotus Elise 135r, Nissan Murano, Honda S2000, 911, Boxster s...and a few more
Post #433593 Mon Aug 18 2014 11:38am
scott1963
have restarted it a few times same thing.have checked the brake lights everything ok.
Post #433595 Mon Aug 18 2014 11:40am
scott1963
would the break light fault restrict the RPM ??? or battery.i am pritty good at trying to hold my head but this car has f......k my head will never buy another land rover.
Post #433600 Mon Aug 18 2014 11:44am
Disco_Mikey
You need to have the fault codes read, to see why all the lights are coming on
Otherwise, its all just guesswork...
Post #433614 Mon Aug 18 2014 1:06pm
BKHK
Try starting the RRS and not the Jeep. It might fix the problem. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #433616 Mon Aug 18 2014 1:42pm
As Disco says, get the fault codes checked out. Also check the brake light switch behind the brake pedal, common failure.
Post #433622 Mon Aug 18 2014 2:33pm
drdelrrs
Might just be worth trying a hard reset - e.g. disconnect battery for at least 30 seconds.
Although the rpm limit potentially sounds more serious
Post #433638 Mon Aug 18 2014 4:48pm
scott1963
We'll jumped back into my rr two hours later
Black magic started and went as if nothing had happend
Very strange.
Noticed that the possative lead on the battery was slack
Mabe this had somthing to do with it
Post #433655 Mon Aug 18 2014 8:27pm
