Home > Maintenance & Modifications > Four wheel wheel allignment |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Choose a garage with the Hunter alignment system from here, should be about £50-60 deoending on the adjustments needed
Tue Jun 17 2014 12:43pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
Lowering the ride height will tend to cause inner should wear because of the way the geometry is. Anyone doing an alignment check will use LR's standard settings for toe, camber etc. 2012 SDV6 - it's missing a couple of cylinders
Tue Jun 17 2014 12:50pm |
