Home > Maintenance & Modifications > Fuel Filler Flap not locking
martyn05
Hi, I have just noticed that when my car (2006 RRS SC) is locked, the fuel filler flap is not.
I can see where the pin should pop out (first photo) and where it should locate in the flap (second photo).
Is this an easy part to replace? Cost?
Many thanks in advance.
 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #422961 Thu May 01 2014 8:05am
hunter
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
I replaced all the clip bits (female side)..but the cost was tiny.(less than £10 ).but so are the parts.. Gone but not forgotten, 2005 RRS SC first edition, BMW 2010 Z4,TVR Tamora, TVR Cerb, MERC SL 55 AMG, E46 M3, Z4, Jag S type R, Skyline R33 GTR 640 bhp, Evo FQ 400, L322 RR, X5, Lotus Esprit V8 twin turbo, Lotus Elise 135r, Nissan Murano, Honda S2000, 911, Boxster s...and a few more
Post #422962 Thu May 01 2014 8:10am
martyn05
Thanks hunter, has anyone ever had to replace the locking mechanism on the fuel filler cap? 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #423056 Fri May 02 2014 12:43am
Walt1900
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
Had same happen to me u cannot buy just the cable u have to buy whole unit called fuel filler cap actuator new around £45 or eBay second hand £25 located behind boot trim or easy fix yourself by extending rod
Post #424573 Sat May 17 2014 5:21pm
martyn05
How did you extend it? 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #424577 Sat May 17 2014 6:08pm
mad-dafty
Scotland 2010 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
I have a similar problem. My fuel flap doesn't lock either. I have noticed a cable/rod? is loose behind the trim...the end of the cable goes into a kind of point is this the rod mention in posts above? If so, is it easy to insert back in? 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
2006 RRS TDV6 2.7 HSE -Java Black
2008 BMW 3 Series 2.l
2006 BMW 5 series 2.l
Post #425563 Thu May 29 2014 12:28pm
