Home > Maintenance & Modifications > lowering a RRS |
MXSRR Member Since: 25 Aug 2013 Location: Lowestoft Posts: 228 |
I think it can be done with the aid of a laptop and the correct software, I'm sure one of the guru's on here will be along to offer some advice MY2007 RRS TDV8 Black - tinted glass - side steps- stormer grille - 20" diamond cut alloys - alpaca leather - TV/DVD pack - some blingy chrome bits & bob's |
Thu Apr 10 2014 4:52pm |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 |
Link rods £80 of eBay |
Thu Apr 10 2014 6:12pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Britpart - EAS lowering tool - no mechanics involved can be reset in minutes 16MY Estoril Blue SVR.............
Thu Apr 10 2014 6:14pm |
sammyc1983 Member Since: 10 Apr 2014 Location: norwich Posts: 11 |
PEACHY how much would this cost me? also i see from your pictures that you have an autobiography kit fitted where did you get it and have you had any problems or anything..................looks mint bud!!! |
Thu Apr 10 2014 8:59pm |
blueiceplus Member Since: 21 Feb 2014 Location: wigan Posts: 66 |
easy done it to mine, no problem got new link rods from ebay £70, and about an hour to fit. |
Thu Apr 10 2014 11:08pm |
Thanks for the comments Britpart do a few IID tools - some are more expensive than others & it depends on what your looking to achieve.The EAS only tool is about £180 - £200 & the more specialist tools can be a hundred or so £ more. The reason I used the tool instead of the links is because its plug & play & reversible within minutes. The AB kit I fitted is Genuine OEM - most of the parts purchased from Duckworth`s - It will be a simple job to do on your Sport - mines a 2005 so a lot more bits was needed. If you have the cash & are not hands on then I would suggest using a company that will do the lot in one hit -purchase the parts - fitting & painting. If not then as TLL suggested you can save money by waiting & sourcing the parts yourself over a period of time. Whatever you decide good luck. Just shout up if you need any help 16MY Estoril Blue SVR............. 17MY Autobiography Dynamic - Corris Grey - WOW. 14MY Autobiography Dynamic - SDV6 - Fuji White 12MY Autobiography - SDV6 - Santorini Black - Dual View - Rear Entertainment - Sunroof. 12MY Autobiography - SDV6 - Orkney Grey - awesome ;( 2005 Java Black - 4.2 V8 Supercharged First Edition- will never be forgotten ;( |
Fri Apr 11 2014 7:30am |
is the IID tool easy to use myself? yeah i keep hearing about duckworth's just thinking i might be slightly priced out by them at the moment and kinda only wanted to spend 2k-2.5k on body kit........................buying the car has left a huge hole in my pocket cheers for all the advise fella!! |
Fri Apr 11 2014 10:32am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
I just use LLAMs - I can select -20 to +50mm below or above any height selected at the simple selection of a switch.
Fri Apr 11 2014 11:22am |
does the ride feal alot firmer?? was hoping to lower about 40-50mm but don't want a really firm ride |
Fri Apr 11 2014 11:26am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Lowered mine circa 25mm, (one inch for old timers) next day put it back to standard, ride does suffer when lowered. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Fri Apr 11 2014 11:55am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
I guess, unlike a lot on here, you lowered it not for the looks SRE, but for the ability to get in a little easier at your age ON THE WAY: BMW F21 M140i
Fri Apr 11 2014 12:07pm |
Agree with SRE anything more than 25 affects the ride height on my RRS - it bounces along 16MY Estoril Blue SVR.............
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
I dropped an RRS once.
Fri Apr 11 2014 1:44pm |
Not allowed to swear on here as the Yorkshire Mods get asrey, but can I ask BC - were your Mum and Dad married??? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
Fri Apr 11 2014 3:00pm |
