Home > Technical > What to have the suspension set on?? |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
Access and offroad suspension height settings automatically reset to normal once you cross and stay above a certain speed threshold. Even if it didn't reset, driving at access height for a prolonged period would give you a bumpy ride and ruin the suspension. Not something the RRS was built for. |
Mon Feb 03 2014 8:05pm |
Alex C Member Since: 09 Jun 2013 Location: Southampton Posts: 146 |
simple solution, go for a set of 22s! you can get the suspension reset to ride lower but I stayed away from that option as the normal road height is good for driving and ground clearance. TDV8 Java Black, Overfinch 22s |
Mon Feb 03 2014 8:12pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
22s on a 2005 TDV6 will possibly shaft the steering rack. LR brought out a revised rack to cope with the move to 20in rims from the smaller sizes. It was fitted as standard on those vehicles delivered with 20s from the factory.
Tue Feb 04 2014 12:22am |
Sorry for the bad advice there, learn something new all the time, least I was right on the ride height! TDV8 Java Black, Overfinch 22s |
Tue Feb 04 2014 6:27am |
medders Member Since: 03 Feb 2014 Location: portsmouth Posts: 148 |
so helpful, im learning so much already |
Tue Feb 04 2014 2:36pm |
