Home > Technical > Rough idle on 2009 RRS 3.6 tdv8 |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Could be an injector harness fault it might show up which one with diagnostic tool. |
Sun Sep 01 2013 6:27am |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 |
I would say egr valve |
Sun Sep 01 2013 5:41pm |
PKS Member Since: 13 Aug 2013 Location: Colac Posts: 5 |
Thank's for replies so far.
Sun Sep 01 2013 10:35pm |
mine used to do this so i bought some egr valve cleaner, you can take the 2 black pipes that go to the throttle body off and spray the cleaner in while reving the engine at 2-3 thousand revs, give it a try as replacing the egr valve on a tdv8 is a big job , i have the launch dia gun which came up with codes for egr on mine |
Mon Sep 02 2013 6:00am |
Hi Cossiedave,
Mon Sep 02 2013 8:39pm |
the 2 big black pipe to the out side
Mon Sep 02 2013 9:56pm |
Thanks I will give it a try and report back. Peter |
Mon Sep 02 2013 10:14pm |
Tue Sep 03 2013 5:59am |
Hi all,
Thu Sep 05 2013 9:17pm |
ross24061986 Member Since: 28 May 2016 Location: United Kingdom Posts: 9 |
I have a 2010 rr sport done 157000, full genuine Land Rover servicing by myself as I work for main dealer.
Sat May 28 2016 7:53pm |
