![]() | Home > Technical > Rough idle on 2009 RRS 3.6 tdv8 |
Could be an injector harness fault it might show up which one with diagnostic tool. |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
I would say egr valve |
PKS Member Since: 13 Aug 2013 Location: Colac Posts: 5 ![]() ![]() |
Thank's for replies so far.
mine used to do this so i bought some egr valve cleaner, you can take the 2 black pipes that go to the throttle body off and spray the cleaner in while reving the engine at 2-3 thousand revs, give it a try as replacing the egr valve on a tdv8 is a big job , i have the launch dia gun which came up with codes for egr on mine |
Hi Cossiedave,
the 2 big black pipe to the out side
Thanks I will give it a try and report back. Peter |
Hi all,
ross24061986 Member Since: 28 May 2016 Location: United Kingdom Posts: 9 ![]() |
I have a 2010 rr sport done 157000, full genuine Land Rover servicing by myself as I work for main dealer.
