Home > Technical > Harsh gear changes |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
Has it ever had a transmission oil change? Might be worth trying that followed by clearing the gearbox "adaptives". 2012 SDV6 - it's missing a couple of cylinders
Thu Aug 15 2013 3:19pm |
c15ebb Member Since: 01 Jul 2013 Location: norfolk Posts: 85 |
No it hasnt.... is that same as the gearbox flush i have read about |
Thu Aug 15 2013 3:43pm |
Its done around 125k aswell |
It's certainly well overdue for a transmission filter and oil change. Worth a try considering the huge cost of a new autobox.
Thu Aug 15 2013 4:50pm |
There are a couple of places advertising "mega flush" but in order to do that they need to cut pipes (the LR install of the gearbox doesn't have a built-in flush system). The normal way is to drain the oil, change the sump (which contains the filter), run the box and then change the oil again I believe. I had this done by an indie for £190 all in. http://www.iawa4x4.co.uk/ You might need to go to a dealer to get the adaptives cleared although some indies can probably do it too. I did mine recently using my IIDTool. It certainly sounds like having the fluid changed is a good first step for your gearbox based on its age/mileage. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Aug 15 2013 8:13pm |
Sweet the £190 sounds good... plus randomly i have 3 litres of the gearbox super expensive oil so might save me a few quid!
Thu Aug 15 2013 8:45pm |
Place and website look very good Easy to see prices etc which is handy! Is the timing belt same as cam belt? i bloody hope so! Mine was done at 96,000 miles cam belt!
Thu Aug 15 2013 8:50pm |
I had mine done at c.60k miles as a general maintenance / precaution item. I'm thinking of getting it done every couple of years in the future.
Thu Aug 15 2013 10:19pm |
Go for it. That is an amazing price considering the plastic sump is £81 retail and the 12 litres of auto fluid for a double flush at the average retail price for ZF Lifeguard would be £240. I've had transmission specialists tell me that if an auto gearbox is on the way out then the only thing that is keeping it working is all the metal particles in the fluid providing the necessary friction and so if the fluid is renewed the gearbox 'dies'. I'm tempted to think this is just one of those 'urban myths' and that what is really happening is that when a gearbox is already worn out changing the fluid doesn't help and so it just happens to fail completely shortly afterwards. But willing to hear from someone who knows better 2008 MY Java Black TDV8 HSE |
Fri Aug 16 2013 10:34am |
According to LR tech today he said he has seen this work... change fluid etc.... as the oil is that good it actually cleans the clutch etc |
Fri Aug 16 2013 2:02pm |
Yes definitely. Lots of threads to show that a fluid change can make all the difference. Had mine done and it definitely improved things. Still have a minor issue but that's another story.... 2008 MY Java Black TDV8 HSE |
Fri Aug 16 2013 2:25pm |
I had mine changed and it didn't seem to do much. When I cleared the adaptives in the gearbox there was a noticeable improvement in gearbox performance. 2012 SDV6 - it's missing a couple of cylinders
Fri Aug 16 2013 11:28pm |
