Home > Technical > Air suspension dryer
domg
England 2005 Range Rover Sport TDV6 SE Siberian Silver
Hi I have done a search and not found much.
I have a suspension issue and I had a look at the compressor it looks to be an air leak issue from the dryer and it seems to be leaking from round the brass inserts for the pilot air pipe and the pressure outlet the pipes seem to fit snug but the air is escaping from what I can feel from round the edges
Are you able to replace the front plate of the dryer as it looks to be held on by Torx bolts or is a new dryer and are there any good suppliers ?
Thanks
Post #385591 Sun Jun 16 2013 1:51pm
Bodsy
Site Sponsor
A new dryer is about £75
You could find another dryer and change it over might as well recharge the silica or put some Fresh beads in there whilst its off. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #385605 Sun Jun 16 2013 4:34pm
flack
why don't you try and cut off some of the pipe and remake the ends off and see if that fixes it, there should be enough spare length for you to try it.
Flack Thumbs Up
Post #385607 Sun Jun 16 2013 5:08pm
domg
Hi thanks for the replies I have found a new dryer didn't realise they were as cheap.
One last question I am going to freshen up the ends of the pipes when I fit the new dryer should the pipes have little brass inserts in them or is it a case of just making sure there square ends
Thanks for the help
Post #385658 Mon Jun 17 2013 7:50am
flack
Some do some don't as long as the pipe is round and not mishapen it does not matter you could cut the ends at an angle, its the roundness of the pipes that makes the seal with an O'ring seal.
Flack Thumbs Up
Post #385659 Mon Jun 17 2013 8:07am
domg
thanks that brill I will give it a try with the new part once rcvd.
one more thing to remove it is it just remove the bolt that holds it to the compressor then pull it off and can you leave the compressor on the car? or like everything on this car it looks simple but you need to remove everything ha ha
Post #385688 Mon Jun 17 2013 12:30pm
