Home > Technical > Sat nav/Radio playing me up |
Jeez. Feel for you on this fault which can see from your other posts it has been going on for a while. Does your car have the sat nav DVD player/computer box under the passenger's seat and did the dealership replace it in one of their many attempts to solve your problem? If not - is it possible this box, which seems to be a bit computerish, is crashing and not switching itself off? Was wondering what would happen if you disconnected the power plug from it (assuming there is one) and then reconnected it. If it had the same effect as your fuse removal and replacement would that implicate the sat nav box? Probably rubbish suggestion - but at least shows we have sympathy 2008 MY Java Black TDV8 HSE
Tue Jun 04 2013 7:48pm |
