Home > Technical > Severed head(light) wiring mystery |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 |
Brake pad wear connector been pulled back into the engine compartment? 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit |
Thu Apr 11 2013 2:20pm |
Thanks. The best suggestion so far Just looked at a new brake pad wear lead and it does have a similar but not identical connector on the 'non-pad end' Would explain why everything appears to working and why there isn't a corresponding lead behind the other headlight (sorry - forgot to mention that in the OP). Suppose if test both severed ends and one is live and one is ground then connect them the dash light for brake pad wear might come on? 2008 MY Java Black TDV8 HSE |
Thu Apr 11 2013 2:50pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
Connector for the TPMS sensors
Sat Apr 13 2013 7:40am |
Thanks Mikey. I'll stop fretting about it Note you were too kind to point out I was wrong about the pad wear function. Light comes on when circuit is broken - not when it is made. 2008 MY Java Black TDV8 HSE
Sat Apr 13 2013 11:35am |
Sat Apr 13 2013 5:27pm |
