Home > General > Have I done the right thing?! |
sagalout Member Since: 26 Feb 2013 Location: Harrogate Posts: 128 |
Quick update. Spoke to the dealer and they genuinely didn't know about the repair (pretty sure they would have just thrown away the invoice if they did!)
Sun Mar 03 2013 10:12am |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 |
I'm not sure you can Re-map a 61 plate 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ))) |
Sun Mar 03 2013 11:24am |
I think you can now:
Sun Mar 03 2013 12:55pm |
In my opinion buy an RRS is like overtaking - if in doubt don't.
Sun Mar 03 2013 2:34pm |
Sag, as you say the warranty is a grey area, if your turbo's go pop, who do you think will pay for new ones? If L/R reflash your ecu which they often do due to updates, you will lose your modified map, as mapping your model requires taking out your ecu and mapping it on the bench, do you really want to be doing this with your motor everytime you take it to the dealers If your dealer suspects that you have had your motor remapped and you have a failure due to this which your mapper will argue the toss till the cows come home that it wasn't his fault, your dealer or L/R WILL void your warranty, L/R have spent millions in research to get these motors where they are today, do you honestly think that they would allow joe bloggs to undo all their research and tinker around with the ecu just to gain more power and still validate their warranty Its been know before for many manufacturers to void warranties due to such modifications. Its all about proving who's fault it is should you have a failure and i think you will find its the one with the deepest pockets that will win. No disrespect to you, but i don't think it will be you on this occasion. |
Sun Mar 03 2013 4:14pm |
hhmm, ok, sounds like I need to think the remap through a bit first. I didn't realise that the LR dealer may just update the map themselves and over write it.
Sun Mar 03 2013 7:25pm |
Some mappers are prepared to put the modified map back on for free should it get wiped, might be worth asking your mapper if he offers this service. |
Sun Mar 03 2013 7:34pm |
Land rover are very clear a remap invalidates your warrant, if like me, your warranty is important, leave it. On the standard map Mike 2014 Facelift Discovery |
Sun Mar 03 2013 7:46pm |
Ok, I may need to get friendly with the command shift! I used it a bit on the test drive and found I could just tap on of the paddles to activate it, but to put it back into 'D' do you just have to move the stick left and then right? I found from a proper stop, eg at traffic lights, take off was fine, but from a momentary stop or just crawling at low speed there was a bit of a delay. Not sure if this is gearbox lag or turbo lag. |
Sun Mar 03 2013 7:55pm |
press the + paddle and hold to return to full auto Mike
Mon Mar 04 2013 9:19am |
Anyone with a moderate amount of computer knowledge and cheap technology can produce remaps and remapped 'chips'.
Mon Mar 04 2013 9:22pm |
Yeah, I've decided against the remap.
Mon Mar 04 2013 9:56pm |
Mon Mar 04 2013 9:58pm |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Enjoy 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Mon Mar 04 2013 10:19pm |
