Home > In Car Electronics > Sat nav problem
Mitchmx
Sat nav problem
After some help.
I bought a newer version sat nav disc from eBay and it come through non genuine. So i tried it and it updated ok. Now it won't let me enter a post code just a zip code and the map is fixed so sometimes it looks like I'm driving the wrong way.
So hunting again I found a genuine sat nav disc put that in and no difference.
After spending a fortune I just want a up to date sat nav. Big Cry
Can I re set my DVD unit then put a genuine disc in or can I buy a disc that updates over what's already on there?
Mines a tdv6 2.7 my2006
Post #368803 Wed Jan 09 2013 10:08pm
Bodsy
Site Sponsor
LOL
When you go to the first enter Destination screen, where the map of Europe is. Press the Map then select UK instead of Belgium Whistle Whistle
For some reason, it always defaults back to Belgium! Thumbs Up
Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #368813 Wed Jan 09 2013 11:28pm
Paddi
Please let us know how you get on with this. I too have a later disc but have not tried it in the unit yet Confused 2008 MY Java Black TDV8 HSE
Post #368875 Thu Jan 10 2013 2:17pm
Mitchmx
It worked! Very Happy but is still the same as the 2006 disc. Can't see what I'm gaining by updating the disc. I only done it because I wanted the version 3 display
I suppose the new roads will be on it but apart from that. Nothing different.
Post #368960 Thu Jan 10 2013 10:29pm
Montythegod
United Kingdom 2006 Range Rover Sport Supercharged Rimini Red
I had the same problem when i bought a genuine disc to update mine to 2012.... Defaulted to europe map Whistle Why?.. Because i can....
RRS 2006 S/C Rimini Red Weekend toy
Subaru impreza 1998 2.0 340hp still here
Smart car 0.7 61 hp Carbon offset
Sierra cosworth 2.0 350 hp GONE
Various RS escorts, Vauxhall sri's Volvo T5's, BMW 3 series, fiestas (?) fiat's....
Mr Mischief - www.mischief-inc.co.uk Wink
Post #368965 Thu Jan 10 2013 10:52pm
mse
The disc only has the maps not the firmware that gives you the display Mike
2014 Facelift Discovery
Post #368968 Thu Jan 10 2013 11:22pm
Mitchmx
How do I update that? Is it a job for bodsey? Mr. Green
Post #368977 Fri Jan 11 2013 12:02am
mse
You might be able to do a slight upgrade but you wouldnt be able to go too far...i cant recall the MY range you can go to sorry Mike
Post #368980 Fri Jan 11 2013 12:28am
Bodsy
Site Sponsor
It changed at 2010 model change I think.
Not sure what you mean by version 3. Do you have a pic? Bodsys Brake Bible
See it HERE
Post #368984 Fri Jan 11 2013 1:33am
mlines
As far as I am aware you cannot upgrade to the latest "look and feel" SatNav as its a completely different system from a different manufacturer.
Any upgrades offered on the older systems will be map updates and bug fixes only. 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #368989 Fri Jan 11 2013 9:09am
mse
You cant go to the new 12MY on system or the HDD navigation system thats on the 10 or 11 on or actually from 10/11 to 12/13 Mike
Post #369040 Fri Jan 11 2013 5:58pm
Paddi
Glad I read this thread - gave me the courage to try my 'bargain' disc which (once I had changed the country to UK from the default Belgium) seems to work perfectly well so far. Smile 2008 MY Java Black TDV8 HSE
Post #369224 Sun Jan 13 2013 9:12pm
sherlock
2008 Range Rover Sport TDV8 HSE Santorini Black
Just been reading this pst as have similar fault. I had to change rom Belgium to UK but ave to do ths every time the sat av sarts up. Did you experience this problem? TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
20" HST alloys, Privacy glass, Side steps, Xenon Adaptive Lighting, Adaptive cruise control
Post #369557 Wed Jan 16 2013 1:58am
Paddi
No; I only had to change from default Belgium to UK once at the 'destination' screen as described by Bodsy above and my �10 fleabay bargain disc appears working just fine. 2008 MY Java Black TDV8 HSE
Post #369588 Wed Jan 16 2013 12:07pm
sherlock
Ok thanks for clarifying TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Post #369591 Wed Jan 16 2013 12:32pm
