Home > General > No competent dealer in Sweden?
EdwardStåhlgren
Sweden 2008 Range Rover Sport TDV8 HSE Luxury Zermatt Silver
Apperantly there are no garages in Sweden that is competent enough to satisfy a swedish range rover owner. Everywhere I look i find complete ignorance. I have just installed a pair of LED DRL lights and contacted My nearest dealer to make them deactivate the automatic headlights. A quite simple task I thought but according to the guy I talken to it was something verk complicated that probably involved sending various computers in the car away for reprograming. I realy didn't think it would be such a complicated job to do as the usermanual refer to the dealer for this task. Could any swedish members recomend a garage that actually knows what a Range Rover is? I suppose there is no orter way to deactivate the automatic headlights?!? Not any fuse that would do the trick?
Post #367861 Fri Dec 28 2012 1:36pm
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Hello mate,
Sorry I can't help you find a decent garage, however have you considered buying a diagnostic tool that will allow you to do this yourself?
There is the faultmate by Black Box Solutions and also the IIDTool by GAP Diagnostic. Both companies are active on this forum, so might be worth dropping them a PM and seeing if their tools can do what you need them to do?
Kav
Post #367862 Fri Dec 28 2012 1:55pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
Hi Edward.
That is pure "B-S" from the dealer..
You don´t have to send anything for reprogramming, it´s easily done with the
diagnostic tool.
Brother has a Disco 3, and had automatic headlight on, and we deactivated it with a faultmate.
I had my RRS serviced by Autoropa, Lidingö, and they had no problems with enabling "auto headlights on"
but I declined, better to turn them on by myself, and better if You are standing idling, without
advertising that the car is running.
If You are the sort of person that does things on the car, servicing and so, I´d recommend either a IID-tool
Faultmate or similar.
There are, as the precious writer wrote, several of the companies active here.
Best regards
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #367932 Fri Dec 28 2012 10:56pm
CeeJay4Fun
Sweden 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
.. And I agrre with Uffe... I imported my RRS 2010 and had the local LR dealer in Hörby to turn on the automatic headlight., i e turn on Scandinavian setting. Easily done by standard LR diagnostic tool (whatever they use). It took 10 mins... RRS 2010 TDV6 HSE Santorini Black
Volvo V60R D5 2011 Black
Jaguar XKR Cab 2002 Blue
Polaris Ranger 800HD Green
John Deere 6430 Premium 2009 IVT, GPS, Very green
Volvo L30B Pro 2012 Yellow
Post #368049 Sun Dec 30 2012 9:54pm
