Home > General > 2010 RRS Suspension Recall
The Engineer
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
We recived an email today from the supplying dealer of the vehicle instructing us to take the car in for an immediate fix to the air suspension. We've run the car for almost 3 years (70k+)with no issues from the suspension apart from a couple of times the car tells us it's not level which sorts it'self after a while.
Can anyone confirm what this recall involves, I also found it strange that it was done via email, as 99% of the time this should has been done via a letter.
Thanks Land Rover RRS 3.0TDV6 HSE Bali Blue
Freelander 2 SD4 HSE Sumatra Black
Ford Focus RS MR375 Ultimate Green
Post #367271 Thu Dec 20 2012 10:12pm
I usually get a telephone call if mine is requiring any T/B's. Bobby is usually the one that gets all the recall notices, i'm sure he will pick up on this post and add his input. Thumbs Up
Post #367272 Thu Dec 20 2012 10:16pm
Nik
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Is a shame they don't do a suspension recall on every sport they've ever built Banging Head
Nik. 2015 Golf R DSG
Gone 2013 Mercedes C220 CDi AMG Sport Plus
Gone 2008 2.7 RRS HSE
Post #367273 Thu Dec 20 2012 10:30pm
The Engineer
Any more ideas on this guys, tried to ring the dealer today but the lines were busy. Probably started the Christmas festivities early Whistle Land Rover RRS 3.0TDV6 HSE Bali Blue
Post #367351 Fri Dec 21 2012 4:54pm
merlin1
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
hope this helps
D4 Air suspension compressor TSB
Just seen a TSB on the system TSB Q213v2
it relates to D4 & RRS vehilces 2009 - 2011 which had a failure of the air suspension compressor and then subsequently had a replacement Hitachi compressor fitted as a warranty repair to have these now replaced with an AMK compressor
so basically if you have a D4, your compressor failed and you have had an Hitachi replaced, this will now be replaced with an AMK version
NOT ALL VEHICLES ARE AFFECTED
if you fall into the criteria above contact your dealer with your chassis number and ask them to check the DDW system where if yours is affected they can arrange to have you booked in
This is a small fraction as only 3200 affected worldwide but best get it checked
Quote:
A concern has been identified on a limited number of service replacement air
suspension compressors fitted to 2009-2011MY Discovery 4 and Range Rover Sport vehicles.
Affected vehicles may experience reduced or no air suspension functionality, including vehicle on
'bump stops' (significant ride comfort degradation) with instrument cluster based warnings
of limited vehicle performance including recommended reduced maximum driving speed of 30
mph (48 km/h).
It is quite possible that the replacement air suspension compressor, installed as a remedy for the
same conditions as those above, will also fail leading to increased customer dissatisfaction.
This does not affect all vehicles, only those which have previously suffered a failure of the Hitachi
supplied air suspension compressor. The number of affected parts and therefore vehicles is
limited to approximately 3200 world-wide; please check DDW for specific vehicles when making a
service appointment to verify eligibility for this Service Action.
Post #367644 Tue Dec 25 2012 10:26pm
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
I drive 2010 May A/B. No emails for me yet Vadim A.
Post #367645 Tue Dec 25 2012 11:26pm
The Engineer
So seeing as we've not had the compressor changed we should not need anything done?
Thanks for posting that, where did you find it all?
Just confirmed we are all good to go not in the recall Land Rover RRS 3.0TDV6 HSE Bali Blue
Post #367658 Wed Dec 26 2012 12:31pm
merlin1
Tsb
You can find all of this Tsb etc on topix hope it helped.
Post #368048 Sun Dec 30 2012 9:54pm
merlin1
Tsb
Post #368050 Sun Dec 30 2012 9:54pm
