![]() | Home > General > Non-standard battery kills alternator - true or false? |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
sounds like b o l l ock s - is it a Stratstones by any chance? ============
whippetman Member Since: 12 Jun 2010 Location: on the level Posts: 502 ![]() ![]() ![]() |
SingeRRS Member Since: 22 Sep 2009 Location: Garage Posts: 127 ![]() ![]() ![]() |
Absolute rubbish - check the ampere hour rating of the two batteries and unless the non OE battery is massively higher (I.e 50% plus which I doubt) the charging current would be virtually identical - and certainly no more than the load on the alternator of running a flat OE battery with the lights and other electrical loads on the car.
Looks like we are all agreed its b---s--t.
JLR reSponse would be that they only recommend the LR one.
so.. is this confirming it IS a s h it stones? ![]() EDIT: they once told me the tolerance between the air suspension on each corner of the car, when on the flat, was.. wait for it... 30% of height value 30% ![]() 2010 TDV8 HSE - ooo laa laaaaaaaaa 2007 TDV8 HSE - superb car and very reliable ============ 2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8! |
It ain't Stratstone. |
is it another Pendragon company (Pendragon own S h it stone) http://en.wikipedia.org/wiki/Pendragon_PLC...and_brands ============
My 'situation' is ongoing.
You should not have a problem as long as you use a lead calcium battery, if you fit a lead accid battery you may find it plays up with Land Rovers (Smart / CAN controlled) Charging System
Yep.
