![]() | Home > Technical > Brembo brakes |
I don't know if you CAN use non-Brembo pads with Brembo calipers but IMO you shouldn't. No point in having Brembo brakes but using pads that aren't upto the mark.
farazk Member Since: 04 May 2012 Location: London Posts: 41 ![]() ![]() ![]() |
Thanks for the reply I will have a look at the site sponsor, I have also been looking on eBay and found a few brembo pads, what's the part number I will need?
bigphil99 Member Since: 14 Dec 2011 Location: N. Ireland Posts: 17 ![]() ![]() |
I just fitted ferodo pads to the front of mine in brembo calipers. I could get them at the local motor factors, about £55. If they didn't fit it was much easier to exchange them. Thankfully they did fit and seem to be as good as (if not better) than the brembo. I still have the box somewhere if you want a part number. With regards the sensor there are two or three different types depending on the chassis number of your range rover so make sure and check first. It is a relatively easy job to do yourself. |
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 701 ![]() ![]() ![]() |
eBay, I've got the green stuff pads on mine and got them off the bay Java black 2006 |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
Land Rover genuine http://www.ebay.co.uk/itm/RANGE-ROVER-SPOR..._500wt_689 |
Thanks for the advice mate, if you could get the part number for me that would be really helpful, are there different kinds of sensors for the brembo set up compared to the standard set up? 2018 SVR |
Have you got a link for it? Did you use them in brembo callipers? Thanks 2018 SVR |
Nice find mate ![]() |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
Best dealer price seems £94+VAT Like this site? Buy some RRSPORT goodies to show your support! |
£112.80 is a lot less than I was expecting from landrover however I may go down the ferodo route like bigphil. 2018 SVR |
Dan (Duckworth) quoted me a forum price of 87.64 + VAT for front Brembo pads so even cheaper. I checked and mine had a good few thousand miles left on them so didn't buy. However, Ferodo should be fine especially as they seem to supply to Land Rover as well. Will PM you regarding front sensor. |
They are dealer cost, you have PM |
Ferodo front pads are FDB1996. The brake sensor I got from dan @ duckworths didn't have enough length on it at the tip to route correctly. It was slightly different from the one I took off. A little digging on e bay and I found two different brembo sensors depending on chassis no. Have a look on there and you will see the different sensors with part numbers.
Thanks mate ![]() |
