![]() | Home > Maintenance & Modifications > MOT Failure |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9030 ![]() ![]() ![]() |
Just realised - the vehicle was serviced less than 3 weeks ago. I'm fairly sure that one or other of the CV gaiter and wheel bearing would have been noticeable then.
Turns out that the wheel bearing was only an advisory (hence not raised at service |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
while the wheel bearing can be replaced, you need a machine shop with a press, plus the extra labour costs involved, it works out more than the cost of a new hub assembly, they would have fitted a complete new unit ( hub assembly ) i had mine done last week, £120 for the hub, plus fitting ( an hour ) plus vat, so they didnt replace it, they must have just tightened it up, so leep an eye on it, as it will become loose again 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
I did wonder if that was the case with the bearing. As it's been done under warranty I'd guess they've changed the hub. How would one tighten the wheel bearing? 2012 SDV6 - it's missing a couple of cylinders
As we were trying a horse out in the trailer this weekend, I had the window open in order to hear any unhappy noises from said beast. Instead, heard a mechanical noise which we assumed was from the trailer. Turned out to be from the RRS wheel that had the gaiter and bearing done. I guessed stone guard and, having taken the wheel off, I was right. They'd managed to press the stone guard against the brake disc resulting in the noise. Oddly, not audible with the window up which is why I hadn't heard it on the drive home from the garage on Thursday. No wonder I was getting some funny looks on Friday at work in the car park!
