![]() | Home > Maintenance & Modifications > Detachable Tow Bar Headache |
Have you tried the 'fix all' solution of spraying a little WD40 on it to loosen anything that maybe stuck ? ON THE WAY: BMW F21 M140i
arbee Member Since: 26 Jun 2012 Location: Dorking Posts: 3 ![]() ![]() ![]() |
Thanks Beancounter
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
Suggest a trip to the dealer and as you are still under warranty a bit of goodwill should be in order even though tow bar did not come with vehicle |
Is the tow bar in the car, or are you trying to do this off the car |
Thanks Guys -
Have you checked there's nothing stuck up inside the car part? Did it have the red 'cover' in it ?
sayers Member Since: 01 Dec 2009 Location: Wiltshire Posts: 106 ![]() ![]() |
i have this same issue, it will be LR job on thursday when the car goes in for being VERY sluggish on pull off and other bits. |
toshers Member Since: 07 Sep 2011 Location: Aberdeenshire Posts: 114 ![]() ![]() ![]() |
The lock had seized on mine. The only way I could get it off was to strip down/disassemble the lock, actually worryingly easy! I was then able to get it off the car. I'm not about to publish how I did it on an open forum, but if you pm me I'll forward a procedure if you're interested. |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Had similar between old and new sport. Spray or grease socket to aid removal. Insert tow bar and whack northwards and it shold lock into place. I put it down to a dry socket ... |
Had to read this twice thought I was on the wrong website for a minute |
Thought that when I was writing but it was tricky enough on the N8 as it was |
Kiwi Graham Member Since: 06 May 2012 Location: Auckland, New Zealand Posts: 24 ![]() ![]() ![]() |
Just a long shot and a bit of a thread highjack;
