Home > Maintenance & Modifications > Detachable Tow Bar Headache |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Have you tried the 'fix all' solution of spraying a little WD40 on it to loosen anything that maybe stuck ? ON THE WAY: BMW F21 M140i
Tue Jun 26 2012 7:54am |
arbee Member Since: 26 Jun 2012 Location: Dorking Posts: 3 |
Thanks Beancounter
Tue Jun 26 2012 8:07am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
Suggest a trip to the dealer and as you are still under warranty a bit of goodwill should be in order even though tow bar did not come with vehicle Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Tue Jun 26 2012 8:13am |
Is the tow bar in the car, or are you trying to do this off the car
Tue Jun 26 2012 8:14am |
Thanks Guys -
Tue Jun 26 2012 9:22am |
Have you checked there's nothing stuck up inside the car part? Did it have the red 'cover' in it ?
Tue Jun 26 2012 9:33am |
sayers Member Since: 01 Dec 2009 Location: Wiltshire Posts: 106 |
i have this same issue, it will be LR job on thursday when the car goes in for being VERY sluggish on pull off and other bits. |
Tue Jun 26 2012 1:15pm |
toshers Member Since: 07 Sep 2011 Location: Aberdeenshire Posts: 114 |
The lock had seized on mine. The only way I could get it off was to strip down/disassemble the lock, actually worryingly easy! I was then able to get it off the car. I'm not about to publish how I did it on an open forum, but if you pm me I'll forward a procedure if you're interested. |
Tue Jun 26 2012 9:32pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Had similar between old and new sport. Spray or grease socket to aid removal. Insert tow bar and whack northwards and it shold lock into place. I put it down to a dry socket ... |
Wed Jun 27 2012 1:14pm |
Had to read this twice thought I was on the wrong website for a minute Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Wed Jun 27 2012 2:36pm |
Thought that when I was writing but it was tricky enough on the N8 as it was |
Wed Jun 27 2012 7:14pm |
Kiwi Graham Member Since: 06 May 2012 Location: Auckland, New Zealand Posts: 24 |
Just a long shot and a bit of a thread highjack;
Wed Jun 27 2012 7:50pm |
