Home > General > Exhaust replacement options?
sherlock
2008 Range Rover Sport TDV8 HSE Santorini Black
Hi guys, (sorry if this should have gone on the Technical section!)
I have the option to go for either
a) a rear box replacement with new pipework only and exhaust tips replacing simply the last few feet of the existing system
b) as above plus replacing and the mid section silencer (up to the cat in effect)
c) as above plus remove the cat but include a 'bullet box' where the mid point silencer was
The prices are competitive and I hadn't really thought about replacing the CAT but the engineer told me this would give most improvement with gas flow etc and wouldn't compromise the MOT. I understand that the sound will increase the more replacement takes place so this will be down to personal preference I assume BUT my question is on option c) will this have an adverse effect, will it not affect the MOT and am I likely to get more smoke coming out of the system.
For information the systems is made of 2.5 or 3 inch stainless steel with chromed polished tips and is priced a) £200 fitted b) £350 fitted and c) yet to be agreed.
What do you think guys? TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
20" HST alloys, Privacy glass, Side steps, Xenon Adaptive Lighting, Adaptive cruise control
Post #330149 Mon Jan 30 2012 12:14pm
ronniet101
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
the pricing seems good from what I can see.
Post #330151 Mon Jan 30 2012 12:21pm
sherlock
any thoughts on the options compared to each other? TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Post #330153 Mon Jan 30 2012 12:33pm
Ballsy
For me I would choose the whole system, will make much more of an improvement
Post #330214 Mon Jan 30 2012 9:33pm
sherlock
Do you mean remove the CAT as well Ballsy? Are you aware of any issues with this mate? TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Post #330216 Mon Jan 30 2012 9:37pm
Ballsy
Yeah, just put it back on for the mot ( or find a friendly mot inspector lol)
I've de-catted most of my previous cars, gives off a much deeper sound and can really help performance.
Post #330218 Mon Jan 30 2012 10:01pm
sherlock
Have you noticed an increase in smoke out that back end or not Ballsy TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Post #330222 Mon Jan 30 2012 10:27pm
Ballsy
My cars have all been petrol, no noticeable smoke whatsoever
Post #330240 Tue Jan 31 2012 7:21am
sherlock
Ok I've made my decision not to replace the cat on my TDV8 RRS as to be honest I do not know enough about the consequence of doing so.
In having read about the diesel particulate filter specifically there is a possibility the CAT has a role to play in burning off the soot from the burnt fuel. Plus there may be some MOT issues
So it looks like a CAT back system on Friday and can't wait.
Thanks for the replies on the post guys. TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Post #330259 Tue Jan 31 2012 10:02am
Supacat
Who's doing this for you and is it commercially avalable?
Post #330260 Tue Jan 31 2012 10:10am
sherlock
A company called Pipe Werx in Lancashire. Really good firm and good workmanship. All systems are Taylor made on site to suit your needs.
I'm paying only £350 fitted with 1.5 mm tubing in either 2.5 or 3 inch stainless steel TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Post #330261 Tue Jan 31 2012 10:18am
kahndesign
i currently have a 3inch downpipe and also a de-cat from pipewerx on the audi and the rest of the system is blue flame.
the pipe werx stuff i cant really grumble with. performance gain on mine from the exhaust and re-map is ridiculous!
Post #330262 Tue Jan 31 2012 10:21am
sherlock
Is it on the RRS ?
Is it diesel and if so how do you find it and have you had any problems. I also don't want masses of boom so how does yours sound mate? TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Post #330263 Tue Jan 31 2012 10:23am
Ballsy
Removing the cat shouldn't cause any soot or smoke, the only job of the cat is to change the "harmful" emissions into not so harmful emissions. It doesn't stop smoke or soot etc.
Changing the backbox on the car can also help performance as this is normally very restrictive.
All cars from around 1992 onwards have to have a cat fitted to pass an mot, if you get a straight thru system then all you need to do is take the cats with the car when you goto get an mot and tell them to put them on for the test and remove them after it, it will cost you half an hours labour or so.
Post #330281 Tue Jan 31 2012 12:14pm
sherlock
Cheers Ballsy TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Post #330284 Tue Jan 31 2012 12:20pm
