Home > Technical > HDC Fault
kelley07
Wales 2007 Range Rover Sport TDV6 HSE Java Black
HDC Fault
Hi - I used my car this morning with no problems or faults. Parked it and when restarting it, it turned over very slowly. Turned it off and locked it to see if anything would reset. Started again and still turned over very slow. Fault on screen showed HDC fault. Decided to drive it home as it was not far. Faults showing on screen - HDC fault - Parking brake fault - All special programs off - Satnav went off - Leaning to side when cornering - No power steering - Indicators stopped working - Window very slow when raising.
Got the car home and locked it - Now it wont open electronically from the key.
Could this just be a battery problem.
I have not got warranty on the car - Car is an 07 model.
Any advice - Thanks Mark
Post #326561 Sat Dec 31 2011 3:13pm
mike21
2009 Range Rover Sport TDV6 HSE Stornoway Grey
Should of got a warranty...................................................................
Not much help but very funny Rolling with laughter Rolling with laughter 2019 BMW X3 2.0i M Sport in metalic black- Brilliant
2014 Mitsubishi Outlander PHEV Atlantic Grey, replaced with 2018 Frost White Outlander PHEV, can't fault em - now gone
2012 SDV6 HSE in Orkney Grey, Privacy Glass & Side Steps (notice a theme)! - Even better but now gone
2009 TDV6 HSE in Stornoway Grey, 20" alloys, Privacy Glass & Side Steps - Fantastic! but gone
Post #326562 Sat Dec 31 2011 3:19pm
firstinretail
United Kingdom 2005 Range Rover Sport 4.4 V8 Siberian Silver
if you get a min, explain the humour, lost on me.
op get the battery checked would be my first port of call.
Post #326569 Sat Dec 31 2011 3:49pm
kelley07
Thanks very much for the advise Firstinretail - Will get battery checked on Monday.
Mike21 - You got a strange sense of humour
Post #326571 Sat Dec 31 2011 3:58pm
ELD70
Get a new battery Thumbs Up
Post #326579 Sat Dec 31 2011 5:50pm
kelley07
Update - Put battery on charge and took it to be checked at Halfords - Battery good. Put battery back on and error reading No special programs on. Took car to local garage and as i drove in - All the previous faults showed again.
Battery was very warm - Cooking.
Alternator fault.
New battery fitted as the old one would now not take a charge.
Battery + Alternator + Labour = £634.04
Thanks for the above replies - Mark.
Post #327132 Fri Jan 06 2012 6:33pm
firstinretail
glad its sorted, not cheap though Sad
Post #327148 Fri Jan 06 2012 8:35pm
"should have" or "should've"
If you're going to take the pi55, at least do it correctly... 2012 SDV6 - it's missing a couple of cylinders
Post #327175 Sat Jan 07 2012 12:38am
Alternator fault.
Eek! You have my sympathies! At least you're back on the road now... 2012 SDV6 - it's missing a couple of cylinders
Post #327176 Sat Jan 07 2012 12:39am
