Home > General > Revs raising and lowering (hunting?) without change in speed |
My auto is slightly hunting at 50mph (top gear at 1200-1400rpms) when on minimal throttle... is this normal?
Tue Sep 27 2011 2:58pm |
Update:
Tue Sep 27 2011 3:13pm |
Linko Member Since: 10 Sep 2010 Location: Shropshire Posts: 61 |
I'd suggest getting a Glycol check on the gearbox oil done 1st, to save wasted money and time. If there is no Glycol contamination, the there is a high chance that the megaflush/double fluid change will work (approx £300).
Thu Sep 29 2011 10:29am |
Thanks Mark.
Thu Sep 29 2011 10:34am |
Not a stupid question at all. The explanation as I understand it is that the oil in the gearbox is cooled by being passed in to an oil cooler in the main radiator. The elment in the radiator can fracture/crack, this means that coolant from the radiator leaks in to the oil that is being circulated from the gearbox to be cooled, which causes the glycol contamination.
Thu Sep 29 2011 11:05am |
RRS gone
Thu Sep 29 2011 4:01pm |
