Home > Maintenance & Modifications > LPG conversion for a RRS Supercharged
cubbyno9
Hi folks, I have a 2006 RRS Supercharged and have heard been told various accounts of the cars ability to be converted for LPG. Does anyone know if it can be done, or not ?
Thanks
Craig 2017 Range Rover Sport HSE
Post #298334 Fri May 06 2011 12:56pm
shepp
hello Cubbyno9
I have recently looked into this, I already have a 90 gassed, but after speaking to four or five specialists. They advised the head needs hardened valve seats, else they will go into recession, giving the engine only a 20-30k miles life.
Have a look at the info below
http://www.jeengineering.co.uk/products/lpg-conversions.html
It is correct i have done a bit of research, I thought initially it was a way of getting more money out of the customer, but the head work is required on the sc.
One reputable converter said they would convert for me but i would have to sign a disclaimer as it will ruen the engine without the head modifying
hope this helps
Post #298338 Fri May 06 2011 1:59pm
cubbyno9
Hi Shepp,
Thanks for the prompt reply. Oh well that's that out the window then.
I will just live with it, have to say I love the car so just a pain to put up with.
Thanks again.
Post #298339 Fri May 06 2011 2:09pm
Bob
2006 Range Rover Sport Supercharged Zermatt Silver
I looked into this a few years ago, but decided that it wasn't worth the effort.
In addition to the hardened valve seals, there is an issue with where to put the LPG tank. Normally it would be mounted where the spare wheel sits, but as this is at an angle on the RRS it wouldn't be possible to use the fuel gauge, and the tank can only be filled to 80% which means that you could only get a limited mileage before a refill.
I didn't really want to take up any space in the back of the car.
I've also heard that LPG can dry out the supercharger bearings (not sure if it's true or not).
So, 5 years later, and I'm still using good old petrol.
Over 50k miles, I calculate LPG would have saved me c.£6k at today's fuel prices. This is not far off the cost of fitting LPG, including having the cylinder heads done, but it's an awful lot less hassle.
Of course, higher mileage would make it a more cost effective option, but then wouldn't it be a more sensible option to buy a more economical car if you were doing really high mileages?
Bob.
Post #298465 Sat May 07 2011 2:14pm
gc
my supercharged was done at 16k its done 65k now and purrs like a kitten but it has got the splash lube fitted which im told is a must
Post #298486 Sat May 07 2011 5:54pm
cubbyno9
Hi Bob, thanks for the reply. Yes I had worked things out cost wise and that it was worth the trouble, and all the doubts about if it con actually be done safely !! Thumbs Up
Hi GC, glad to hear that you have managed to get it converted successfully. Who did the conversion? Cheers. Thumbs Up 2017 Range Rover Sport HSE
Post #298863 Tue May 10 2011 8:48am
