Home > Technical > need a new alternator for rrs
billyboy43
England 2005 Range Rover Sport TDV6 HSE Java Black
hi im billyboy i recently had a problem with my alternator i think as sumone has told me. al th dash bored was flashin like a disco and the engine just slowed down then stopped. went to it this morning and no power at all. does you think its my alternator
Post #297678 Fri Apr 29 2011 3:03pm
Its a good starting point, have you checked all your wires to the alternator and check to see if you battery terminals are tight and clean, it might be your battery that is Censored but get it tested, Thumbs Up
Post #297680 Fri Apr 29 2011 3:22pm
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
If you get the car started again and have access to a multimeter then you can test to see the alternator is charging at the battery terminals.
Post #297681 Fri Apr 29 2011 4:04pm
timcom0
Re: need a new alternator for rrs
Are you in AA as they would test it for you and check battery
Post #297684 Fri Apr 29 2011 5:03pm
