MikeS
Had this a couple of times with mine, but nothing like as bad as you seem to be encountering. Only happened when it was extremely cold as well, so again, not something you'll be suffering I expect. It misfired for the 1st few seconds then cleared, even stalled a couple of times. I've certainly had the throttle delay as well.
All I can suggest is checking to see if it has an air leak, when the engine's running look at the breather valve on the left hand side of the engine (as you stand looking at the front, it's a black circular object mounted at the front of the rocker cover)) and see if it's whistling, if so then by pressing down on it you'll hear the whistling stop / start. If that's whistling, you have an air leak on the induction system and if it's anything like the grief I've just had with my 4.4 NA, you'll need a new throttle body to fix it. Start by taking off the induction pipe and looking at the throttle butterfly, if it's covered in a sheen of oil, clean it all down with solvent and that might make an improvement. Ex-G4 Challenge RRS HSE, BV55 YZE. Subtle shade of orange ! Now registered YZE481 G4RRS in Melbourne.
Thu Mar 03 2011 5:54pm |
