Home > Technical > Frozen washers - where to look to thaw?
Mail Order Ride
Hi
Its been -9 here for 2-3 weeks and despite running 50/50 screenwash my washers are frozen solid
Front, rear and headlamps all non functional
I can hear the relay click when I hit the button but theres no sound from the motor
Now I admit the car has only had light use for 2-3 weeks, and nothing longer than a 20 minute run
I need to do a 4h trip later in the week, will the heat generated by the engine eventually thaw it out do you think or is there a likely sweet spot for me to attack with a hairdryer?
As absolutely nothing works my favourite theory has to be the whole reservoir frozen solid, but if so it should thaw out if I run the car for a few hours?
Shouldnt it??
Post #283698 Tue Dec 21 2010 12:27pm
DSL
50/50 mix way too weak at that temp, you need to run neat. Also engine heat does nothing to warm up the bottle when driving as the bottle is in front. If you do get it thawed out vent out the weak stuff and get much richer stuff in there, don't forget to flush the stuff through. Also don't take the figures on he screen wash container as gospel, the stuff I use is rated to -15c but doesn't work in a D3 under -11c.
Post #283699 Tue Dec 21 2010 12:50pm
pcregeen
I spent 9 hours running yesterday on journey from south coast yorkshire. Washer did not defrost once and i have a real high concentrate. When your moving, the sheer wind chill factor stops any additional heat from the engine. This 2.7 struggles to keep itself warm, let alone let excess heat go!!.
In short, i would keep a squirty hand held bottle in the drinks holder. SWMBO did a stirling job Laughing
Post #283700 Tue Dec 21 2010 12:52pm
AlexMckie
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
I lost mine for a whole week... Only thing to do is get it in a garage and put a parafin heater under the nearside front corner for the night.... or two....
Then empty the reservoir and put neat wash in....
Alex
Post #283710 Tue Dec 21 2010 3:02pm
MikeS
Australia 2005 Range Rover Sport 4.4 V8 HSE Tangiers Orange
Have neat screenwash in at the moment and that froze up on Monday once the outside air got to about -10, with the wind chill of 70mph on the M50 it was likely a shedload colder than that Laughing
More worryingly, when they did work at about -8, once the screen was clear the moisture froze instantly, I had to put the heated screen on so I could see !!
Colleague has suggested pouring a litre of antifreeze in the bottle, he's using it in his car at the moment and it seems to be working. Mind you, he does have a company car so the bill's not his if it goes wrong.... Ex-G4 Challenge RRS HSE, BV55 YZE. Subtle shade of orange ! Now registered YZE481 G4RRS in Melbourne.
Post #283715 Tue Dec 21 2010 4:32pm
marksgd
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Hi soundslike you got same problem as me when i pushed the washer button heard a click no motor sound ....fuse had blown located behind lower glove box fuse number F18.. 5amp Hope that helps... Smile
Post #283726 Tue Dec 21 2010 6:27pm
DSL
5 Amp?? In D3 it's a 15A, updated from 10A.
Post #283728 Tue Dec 21 2010 6:29pm
Steuart64
Scotland 2011 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
If you have room put neat winter wash in. It may just be enough to thaw and seep throught the system. Have seen other posts where thay put in hot water from a kettle and putin an aqaurium style water heater!!!! Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!!
Ex- RRS HSE TDV6 07 Java Black, bi xenon, corner lights, side steps, tints, cool box, smoke side repeats, chrome "sport" boot sill
Ex - Audi A4 Cab 3.0TDi Quattro
Ex - Freelander2 SE TD4
Ex - CRV Auto
Post #283732 Tue Dec 21 2010 6:41pm
Mail Order Ride
-1 this morning so I drove it 10 mins to work and its now working again
I have drained the tank and will refill with more concentrated solution
Post #283814 Wed Dec 22 2010 7:21pm
marksgd
Where do you drain the tank , think thats what ineed to do as mines still not workin
Post #284059 Sat Dec 25 2010 6:26pm
DSL
Press button at end of stalk, or long straw!!
Post #284060 Sat Dec 25 2010 7:16pm
marksgd
Tried the end of stalk its frozen you got a long straw Smile
Post #284063 Sat Dec 25 2010 8:22pm
Tim in Scotland
I believe in the old days before Global Warming when winters were always this cold people used radiator mufflers or the less affluent blocked the radiator grille with aluminium foil or cardboard - neither foil nor cardboard is very elegant but they do the job of restricting the icy blast of air through the plastic front grill and helps your engine warm up more quickly on a cold morning once you have got moving. I know you can buy proper waterproof mufflers for a Defender (they are also used to stop really muddy water clogging the radiator fins if you are wading through muddy bogs and water) I doubt anybody has got round to making one for any of the more delicate and prettier models - I suspect there isn't much demand for them normally! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #284077 Sun Dec 26 2010 5:52am
DSL
So they do one for the RRS then?? Ner Ner Whistle Wink Thumbs Up
Post #284087 Sun Dec 26 2010 10:10am
marksgd
You are right DSL just looked in the manuel Fuse no: 11 15Amp Washer Pump Fuse 18 is 5Amp but its for rain sensor/light senser....... Rolling Eyes Still aint got no water though Sad
Post #284091 Sun Dec 26 2010 12:04pm
