![]() | Home > General > Overheated supercharger? |
Misery Member Since: 07 Dec 2005 Location: Waiting for L405 Posts: 2555 ![]() ![]() |
RichardM Member Since: 24 Sep 2009 Location: Herts Posts: 745 ![]() ![]() |
Sounds like the E270 I had. That went into limp mode on the way to a stag weekend in Cornwall and wouldn't even go up a hill. Thankfully the few trips I have done down there since have been in the Alfa which has been faultless. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Bladerider Member Since: 06 Aug 2010 Location: Speedfreak County Posts: 8 ![]() ![]() ![]() |
Sounds like a boost leak causing it to overboost which the ecu then doesnt like.
It is very rare that the supercharger itself fails.
avos Member Since: 26 Aug 2008 Location: Belgium Posts: 106 ![]() |
Usually you would be able to find codes, did they check with the right tools that can read all propriety codes from the RR?
marc777 Member Since: 26 Apr 2010 Location: Oxfordshire Posts: 69 ![]() ![]() ![]() |
Thanks for the input. On the Merc it was the intercooler pump that would overheat and then shut down. I'll see if I can get LR to to a diagnostic. Thanks Avos 2007 RRS Supercharged, Black & Ivory, 22" Overfinch and MY10 rear lights.
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
yep you should do this ! |
rockportpurple Member Since: 30 Apr 2009 Location: scarborough Posts: 26 ![]() ![]() ![]() |
hi all my supercharged has just strarted with the same fault it will go into limp mode after a few hot runs and i have turnde off the ignition left it five min and it has rectified itself,but it is booked in tomorrow as i have been told it is either thepump or the positive or negative that was misswired at the factory
LTB00041v2 concerns "Reduced Power With The Possibility Of Diagnostic Trouble Code
Bobby once again as always. |
Bet there will be queues of S/C RRS owners at dealers tomorrow to get their cars checked out |
i start to think that Bobby may be 007 !!!! |
Thanks for that. The trip certainly involved lots of +/- and so I think this may be the answer. Will report back later in the week as I am told Truro's LR dealership tends to be stacked out on a Monday dealing with holiday maker vehicles as well as the local LR population. |
![]() ![]() ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
