Home > Maintenance & Modifications > Wheel Wobble , again
PAULD
Hi guys , I am generally lurking here but after so many issues with my 2009 TDV8 HST I needed to post.
Having had a whole lot of work done recently under warranty , I decided to get my 22's p/coated & back on the car , since then the wheel has been wobbling like crazy , I have searched & seen plenty of threads on the wheels shimmy issue & to be honest , I am just sick of this car now!
The only other thing I can think of is that when the guy did the wheels he also did the inside part of the wheel where it bolts to the hub , surely this would not cause the wobble? Maybe I should wet n dry it to make sure?
Thanks in advance!
Post #262492 Fri Apr 09 2010 7:57am
MAW
Did you have them rebalanced after coating ?
Post #262509 Fri Apr 09 2010 11:02am
Martin
Site Administrator & Owner
If you have powdercoat on the the mating face then they won't bolt up flush - quite probably giving the wobble you've mentioned.
Very surprised they were given back to you like that Shocked Like this site? Buy some RRSPORT goodies to show your support!
Post #262511 Fri Apr 09 2010 11:08am
