Home > Maintenance & Modifications > Misfire / judder on acceleration - any thoughts?
bevlawyer
60k rrs v6 just serviced. Then problem developed. Under firm acceleration engine misfires and judders horribly. Seems worse from cold. Had egrs flagged on diagnostic so got those blanked off, problem still persists and is getting worse. Anyone know of any known issues?
Post #261209 Sun Mar 28 2010 8:36am
bevlawyer
Research this morning has thrown up:
1. Plugs
2. Ecu
3. Water in fuel
4. Turbo pipe split
help !????
Post #261216 Sun Mar 28 2010 10:21am
sweetafton
England 2011 Range Rover Sport Supercharged Santorini Black
How did you come up with these mate? Shocked
Post #261217 Sun Mar 28 2010 10:25am
bevlawyer
Just from googling around. Any ideas yourself?
Post #261218 Sun Mar 28 2010 10:29am
sweetafton
Well if just serviced by main dearler then all filters would of been changed so no water in fuel. With diesel then plugs should be ok. Split in turbo hose or ecu could be. Do you have any break down cover cause they could have a look free of charge. Turbo hoses can be done diy but ecu will be dearler. Big Cry
Post #261221 Sun Mar 28 2010 10:59am
bevlawyer
Thanks. Would the split turbo hoses be visible under bonnet ie for me to diagnose?
Post #261226 Sun Mar 28 2010 11:45am
sweetafton
Even a pro would find it hard to find a small split. Check all the hoses anyway you never know. Its a big engine so as long as your a bit confident you might be ok. Good luck. Thumbs Up Thumbs Up
Post #261236 Sun Mar 28 2010 2:42pm
5c0tty
United Kingdom 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Hi bevlawyer
My RR is having the same issue after just been serviced. Did you get to the bottom of your issues
Scotty
Post #370583 Tue Jan 22 2013 8:55pm
