Home > Maintenance & Modifications > Misfire / judder on acceleration - any thoughts? |
bevlawyer Member Since: 08 Jun 2009 Location: derby Posts: 22 |
Research this morning has thrown up:
Sun Mar 28 2010 10:21am |
sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961 |
How did you come up with these mate? |
Sun Mar 28 2010 10:25am |
Just from googling around. Any ideas yourself? |
Sun Mar 28 2010 10:29am |
Well if just serviced by main dearler then all filters would of been changed so no water in fuel. With diesel then plugs should be ok. Split in turbo hose or ecu could be. Do you have any break down cover cause they could have a look free of charge. Turbo hoses can be done diy but ecu will be dearler. |
Sun Mar 28 2010 10:59am |
Thanks. Would the split turbo hoses be visible under bonnet ie for me to diagnose? |
Sun Mar 28 2010 11:45am |
Even a pro would find it hard to find a small split. Check all the hoses anyway you never know. Its a big engine so as long as your a bit confident you might be ok. Good luck. |
Sun Mar 28 2010 2:42pm |
5c0tty Member Since: 14 Sep 2012 Location: London Posts: 33 |
Hi bevlawyer
Tue Jan 22 2013 8:55pm |
