Home > Maintenance & Modifications > TDV6 D3 and RRS Decat front pipe £76 inc delivery
bellautos
United Kingdom 2005 Range Rover Sport TDV6 HSE Cairns Blue
As title realy , im selling D3 and RRS TDV6 decat front pipes for £76 all inc deliverd to UK.
They are made from 409 stainless steel which is a mix of mild steel and stainless.
The same stuff landrover use to produce there exhausts.
Its a straight swap no modification to the car or mountings.
If you are intrested please pm me, i will be adding photos soon.
Regards Pete
Post #210085 Thu Feb 05 2009 2:23pm
Hangover
Belgium 2008 Range Rover Sport TDV8 HSE Alaska White
If you're planning to make these for the TDV8 in the near future please let me know. RRS TDV8 Alaska White,Remap, JE exhaust,DPF Removed
Post #257387 Fri Feb 26 2010 2:45pm
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Any benifits to performance or consumption Question
Post #257391 Fri Feb 26 2010 3:30pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
and does it need a re-map after fitting? Sons of dogs come hither and get flesh
Clan Cameron
Post #257393 Fri Feb 26 2010 4:39pm
BIG DJ
Would imagine that it would be ok without a remap as it wouldnt effect the AFR's that much but would give a bit more performance as there would be less resistance for the exhaust gases.
I may be wrong tho as not a proffesional tuner. Sure Bellautos will let us know tho Thumbs Up
Post #257408 Fri Feb 26 2010 6:22pm
Steuart64
Scotland 2011 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Ignorance is bliss - well easier on the plastic but i will ask anyway Rolling with laughter
What are decat front pipes ? Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!!
Ex- RRS HSE TDV6 07 Java Black, bi xenon, corner lights, side steps, tints, cool box, smoke side repeats, chrome "sport" boot sill
Ex - Audi A4 Cab 3.0TDi Quattro
Ex - Freelander2 SE TD4
Ex - CRV Auto
Post #257414 Fri Feb 26 2010 7:15pm
Tim in Scotland
Steuart - the exhaust down pipes without the catalytic converters! VERY expensive to replace when they are dud 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #257416 Fri Feb 26 2010 7:18pm
BIG DJ
Anyone know how easy these are to fit on a RRS yourself? I mean are the bolts all easily accesible?
Post #257418 Fri Feb 26 2010 7:22pm
Steuart64
Ahhhhhh another fog bank lifted!! Many thanks Tim Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!!
Ex - CRV Auto
Post #257422 Fri Feb 26 2010 7:29pm
Tim in Scotland
Normally when you remove the cat froma TD engine you are recommended to also remove the EGR and Lamda probe otherwise you are sending info to the ECU that it cannot use and it can cause problems. This was what I was led to believe when I had the cat on my TDi300 Defender fail a few years back. Removing the cat, EGR and the associated electronics made the car run more smoothly and it used less fuel. I'm not sure of the MOT regs for modern cars, but my Defender is 14 years old and at every MOT sails through the emissions test with no problems without the cat. I promptly undid the saved fuel situation by fitting aggressive mud tyres to it Mr. Green 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #257423 Fri Feb 26 2010 7:34pm
dazsear
Pete
You might want to have a chat with me since my mate owns www.jacexhausts.co.uk and makes a lot of exhausts for big company's.
Let me know if you want an introduction to discuss prices and discounts.
Daz 2017 4.4 Autobiography FFRR - love this car
Gone - VW T5 Transporter
Long gone - 2009 Disco
Long gone but never out of my thoughts - 2008 TDV8 HST
Post #257424 Fri Feb 26 2010 7:48pm
BIG DJ
Good points Tim Thumbs Up
On my previous car removing the front CAT also threw the engine managment light on.
I assume that there is a CAT further back too? So may not have issues with MOT.
Would it make much difference removing the front CAT without removing the other one too?
Post #257425 Fri Feb 26 2010 8:03pm
bellautos
What did you remove the cat on ? if a non electrically moniterd cat on a diesel is remove it cant bring a light on.
To confirm at the moment the MOT does not need a cat test on a diesel so removing it wont make the car fail.
Pete
Post #257499 Sat Feb 27 2010 6:51pm
BIG DJ
Pete
Cheers Pete Thumbs Up It wasnt a diesel, it was Mitsubishi Evo Wink
Are there other cats or is this the only one? Sorry RRS's are new to me!
Post #257504 Sat Feb 27 2010 7:34pm
bellautos
Ahh that explanes it then, pertols are all moniterd with oxygen sensors.
re the other cats, on most v6 diesels rrs there is only 1 cat, depending on the year model etc some may have a DPF also which is different to a cat.
Pete
Post #257506 Sat Feb 27 2010 7:38pm
