Home > Maintenance & Modifications > WARNING - 2010MY Rear LED light upgrades
NasMan
Regarding 2010MY Rear LED lights
These apparently fit any Range Rover Sport, but you MUST upgrade the wiring at the back to include a resistor:
There are many being sold without the resistor so DON'T get caught out..
Can someone Technical confirm??
See below for one that DOES come with a resistor:
http://cgi.ebay.co.uk/Range-Rover-Sport-20...1304wt_732
EASY DIY FITMENT WITH ONLY A COUPLE OF SCREWS TO REMOVE EACH UNIT AN CLIPPED OUT FROM THE REAR QUARTER
PLEASE NOTE AS THESE ARE LED UNITS RATHER THAN THE ORIGINAL BULB UNITS THAT ARE FITTED WE NOW SUPPLY ADDITIONAL WIRING AND A RESISTOR THAT WILL HAVE TO BE PUT IN PLACE BY AN ELECTRICIAN, A SIMPLE JOB FOR ANY ELECTRICIAN OR DIY ENTHUSIAST, THIS WILL STOP THE INIDICATOR SYMBOL ON YOUR DASHBOARD FLASHING TWICE AS QUICK AS IT BELIEVES A BULB IS OUT DUE TO THE LOWER AMPERAGE THAT THE LED BULBS DRAW
WE SUPPLY FITTING PICTURES AND INSTRUCTIONS ON CORRECT INSTALL
Without the resistor they DO NOT work properly 57 RRS | TDV8 HSE | Java Black | Black Interior | Side Steps | 20" Alloys
Bought in Januray 2010. Colour Coded Car with Forum Members Help.
CURRENT - 2004 Mercedes SL350 | Silver - Best Car I have ever had Smile
GONE - Jaguar S-Type | Silver
Post #250941 Thu Jan 21 2010 9:52am
Martin
Site Administrator & Owner
mjlperformance on eBay = DCC4x4 on here Thumbs Up Like this site? Buy some RRSPORT goodies to show your support!
Post #250944 Thu Jan 21 2010 10:19am
merwiz
How much of a job is it to fit this 'resistor'??
I'm sure i've seem some advertised with the correct bits fitted so they just 'plug into' the car, no fiddling needed.
Thumbs Up I keep telling myself 'It's a toy'
But I've broken quite a lot of toys in my time.....
Post #250949 Thu Jan 21 2010 10:44am
NasMan
I have asked DCC4x4 via ebay, Maybe they can respond in this thread, as they do have full fitting instructions... 57 RRS | TDV8 HSE | Java Black | Black Interior | Side Steps | 20" Alloys
Post #250950 Thu Jan 21 2010 10:45am
DCC4x4
Site Sponsor
hi, basically we supply the resistor built into the wiring with a fuse built in for safety, you just need to earth one end of the wire and drille 2 holes to attch the resitor to the inner bodywork, the other end of the wire is soldered onto the the indiator wire either side after stripping the outer cover of the wire down about 1cm, i hope this helps regards martin dcc4x4 As long as your alright
Post #250952 Thu Jan 21 2010 11:03am
NasMan
DCC4x4 any forum member disocunts? 57 RRS | TDV8 HSE | Java Black | Black Interior | Side Steps | 20" Alloys
Post #250953 Thu Jan 21 2010 11:09am
DCC4x4
Site Sponsor
YES FOR SURE, I DO NOT SELL THE WIRING SEPERATLY AS I ONLY HAVE LIMIED PACKS AND WOULD END UP JUST SELLING THEM TO POOR CUSTOMERS WHO HAVE BEEN RIPPED OFF ON PLUG AND PLAY PURCHASES GONE WRONG, THEY NORMALLY RETAIL AT £379 I WILL GIVE 15% OFF REGADS MARTIN As long as your alright
Post #250958 Thu Jan 21 2010 11:36am
tornado34
2006 Range Rover Sport TDV6 HSE Zambezi Silver
I bought mine with the resistor already wired in and fixed within the light unit, they work fine.
The wiring was neat and very well soldered and insulated.
As the resistor appears to only affect the indicator lights, the heat generation from the waste load isn't too great. I left may hazzards on for 2 hrs the other day as I was on site, and there was no issue.
Resistors used on 'always on' lights (tail lights, sidelights etc) need to have some form of heat sink to dissipate the heat (in my experience of loading LED's to stop bulb failure warnings appearing).
Mine were simply plug and play Thumbs Up
Post #250968 Thu Jan 21 2010 12:32pm
