Home > General > Dash lite up like a Christmas tree (oh no!)
Frosty_Power
Canada 2006 Range Rover Sport 4.4 V8 HSE Alaska White
Hi guys,
Need some help here. '06 RRS dash lights all(or most) went on last night when I started it up. Never turned off. Lots of fault messages on the screen. The speedometer stopped working also Big Cry . Vehicle has around 120K Kms on it. No past issues. I am assuming it is the battery or the alternator as this has happened before to us on a different vehicle(different make). Any thoughts???
Thanks in advance,
Mike
'06 RRS
Post #241063 Fri Oct 23 2009 3:19pm
Martin
Site Administrator & Owner
Sounds like it could be a low battery voltage problem - what temperature is it in Calgary at the moment? Like this site? Buy some RRSPORT goodies to show your support!
Post #241064 Fri Oct 23 2009 3:38pm
Frosty_Power
It's 2 degrees C. Was -5 degrees C last night.
Post #241065 Fri Oct 23 2009 4:04pm
Frosty_Power
Here's a pic
Post #241066 Fri Oct 23 2009 4:09pm
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
I had similar on my car and the dealer told me it was low battery charge
Post #241085 Sat Oct 24 2009 11:54am
Frosty_Power
Thanks Martin and 2nd Rover for the responses.
Took the RRS to the shop to pull up all the error codes. They told me it was 2 sensors that need replacing, one on the transmission and another on the rear wheel speed sensor. It's going in for repairs tomorrow. Strange that these 2 sensors would lite up my whole dash like a Christmas tree(a little early for that Laughing ). He said it could just be loose or may have been disconnected if I went offroading(which I didn't). Asked about the battery voltage and alternator and they said it tested fine, told me I couldn't even drive this far if it were that which makes sense. Oh well, will keep you guys updated on the status, hope they don't find anything else wrong Shocked .
Post #241325 Tue Oct 27 2009 5:54pm
Frosty_Power
Hey guys, just to give you an update. It was just a faulty rear wheel speed sensor. It's been replaced and is all good once again. Sensor was $75 CDN and charged 0.5 hrs labor.
Post #241551 Fri Oct 30 2009 7:13pm
