![]() | Home > Maintenance & Modifications > Finally.....S/C grille & vent |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
Hoorah!
Cool |
Hooray!! Good work, Super... I think the outlay for the Tigers might be a little harder to sell |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
de la stupid question from a foreigner with spelling probs: how much will u pay or did u paid for that modification ?
A set of Tigers with tyres fitted costs about £3500 I believe... |
Arqiva Member Since: 04 Apr 2006 Location: Winchester Posts: 11 ![]() ![]() ![]() |
Guys,
NeilR Member Since: 21 Jun 2005 Location: wakefield/West Yorkshire Posts: 246 ![]() ![]() ![]() |
Tiger £3250 fitted, Just had mine fitted last week, the car looks really good with them on
kam100 Member Since: 28 Sep 2005 Location: In my office doing quotes!! Posts: 4771 ![]() ![]() |
back in aug.. paid grill vents, and lr badge kit, rear badge, wheel centres £180 delivered. well worth it.. ( oh and i found em on ebay..) |
zhat ist cheap ! |
Sorry Angel, I thought you meant the Tigers |
£126 ??????????
I've since found that dealers markup (I expect with most parts actually) on these items is immense - you've seen what they are, just noddy bits of moulded plastic. I saw someone on here once quote £200 for a front grille, that's just a pi** take. |
Guys, just go back from dealer now.
There are a couple of threads, Super, but going back some time... I was asking the same questions when I wanted to fit mine. The front grille is easy enough, you should be able to see how to do that simply by lifting the bonnet. Two lugs on the top which pop out, then pull it up/out and it comes away without too much difficulty - might just be a bit stiff. It's the side vents that require you to wear the brave hat |
