![]() | Home > Maintenance & Modifications > Knocking Noise |
Worzel Member Since: 27 May 2009 Location: Lancashire Posts: 123 ![]() ![]() |
Well Here goes with the update........
.....not to depress you further, but the bush replacement exercise is a waste of time.......your noise will be back in no time. |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 ![]() ![]() |
Will - in some cases, the bush replacement works, so it's best to get it done and then see if the noise is still there |
For the lucky ones maybe, but for us hardcore whiners ![]() ![]() ![]() ![]() Cannot wait to get my hands on the new one..........a single {Lada} sounding knock and that's me ditching RRS's forever, 3 poxy years is enough. Premium, more like Pathetic ![]() 5 series for the miles ![]() RRS S/C factory built HST - Gone 45 others have been and gone! |
Update v2.
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 ![]() ![]() ![]() |
Worzel - any chance of posting up further details of what parts were used? |
As soon as i have them you guys will be next............ |
Look forward to it |
Here you go guys its here
Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
So they have replaced the active roll bar rubber mounting bushes, fitted new type 35mm lower wishbone ball joints and new steering rack tie bars (they have a ball joint at the inner ends). |
949BFN Member Since: 16 Apr 2007 Location: Bloemfontein Posts: 59 ![]() ![]() ![]() |
My partner and I have the same issue with our RRS (his the V8 diesel, mine the Supercharge). His went in for the umpteenth time today to get the problem fixed. South African models come from the UK, so the dealer reckons TLB00204 does not apply in South Africa. (I tried to find the UK equivalent of this bulletin, but the technical site seems to be down again). The dealer today removed two small shock absorbers from somewhere underneath the vehicle, telling us that these shocks are the reason for the knocking noises and “the vehicle don’t really need them”. I did not see where these were removed from, but they remind me of those shocks keeping open the bonnet of a vehicle, only much shorter. (About 12 cm in length I would guess). I don’t for one minute believe that this could be the cause of problem. They wanted to remove my vehicle’s as well, but I refused. I will look under the vehicle this weekend to see if I can see where the shocks were removed from my partner’s vehicle. 2010 Sport Supercharged with all options apart from TV and Extended leather (wish I had the latter) (Previously 2007 RRS S/C) |
Read this thread.. Malaysia Boleh!
Thanks Bobby, I've been keeping track of that one. Anything in particular I should look at? Or are you saying it's a waste of time to have the bulletin done? I can't remember reading of the "removal of the small shocks" solution yet. (I know it is not going to help - there is no way those could be causing the amount of noice we have. I'm more interested in what the purpose of these shocks are and why Land Rover would want the dealer to remove them) 2010 Sport Supercharged with all options apart from TV and Extended leather (wish I had the latter) (Previously 2007 RRS S/C) |
949BFN,
