Home > General > Blackberry Phone/RRS connection issue.
Bodster2
Portugal 2008 Range Rover Sport Supercharged Lucerne Green
I've had my Blackberry 8300 pared with my RRS for sometime now but when I went to drive the car the other day, the RRS did not pick up the Blackberry signal. I tried re-paring it by entering the code and that worked but I then get a message saying that the RRS is waiting to connect but nothing ever happens.
I've retried this process over and over again but the RRS still fails to find connect with the blackberry.
Has anyone else encountered this and if so, where you able to fix it?
Cheers Very Happy 2008 RRS Supercharged
Lucerne Green, HST Kit, 23" Rinspeed Alloys, Side Steps, Mud Flaps.
Post #222508 Wed Apr 15 2009 6:33pm
vogue se
Belgium 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Works fine with me.
P
Post #222596 Thu Apr 16 2009 10:43am
Sometimes rebooting the phone helps. (You might have already tried this though.) 2005 Zambezi TDV6 - Gone but not forgotten
Post #222597 Thu Apr 16 2009 10:46am
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
I've just changed to a Blackberry Storm. Had a few problems with bluetooth to begin with and had to play around with the phone settings a little before I got it to pair automatically each time I get in the car.
Now it works perfectly every time.
I just need to sort out the b Censored y email now. Evil or Very Mad Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #222612 Thu Apr 16 2009 12:41pm
Bodster2
Finally managed to fix the problem. Turned the phone on and off a few times but that didn't work. I then took the battery out, put it back in then turned it on and it now connects with the car. Not sure what the problem was but it's sorted now. Whistle 2008 RRS Supercharged
Post #222668 Thu Apr 16 2009 11:32pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Some Blackberries - especially earlier models such as 81xx and 83xx - have the nasty habit to eat free memory slowly as you use their software or third party apps, and the only way to truly release the memory back to the phone is to quickly disconnect the battery; Turning the phone off and on doesn't really do it (kind of like a Range Rover Sport, ha ha.) If you don't refresh available memory, eventually things start disappearing - call logs, sent messages, etc. - and everything gets real sluggish and/or hangs, including the BT radio. I have figured out my Pearl needs the battery trick done about once a week to stay in tip-top shape, although memory management seems to have gotten better with each firmware release by RIM.
Post #222673 Fri Apr 17 2009 3:53am
Josh
I'm about to be given one of these Blackberry 8100's by my employer.
So can my bluetooth cope with having more than one phone paired with it at the same time or do I have to use one phone at a time or would it be easier to just divert the Blackberry to my Nokia Question TDV6 - gone
TDV8 - gone
Post #222694 Fri Apr 17 2009 10:03am
hsv123
my blackberry always cuts off when on bluetooth mode in my wifes honda civic!
Post #222816 Sat Apr 18 2009 4:24pm
