![]() | Home > General > Rear heated seats |
No there is no indication in the front that the rear seat heaters are on, unlike the front seat heaters. You could remove the fuse or disconnect them under the seat. As a last resort you could chop off the child's hands.......... but that is a bit drastic. I would imagine that out in Cyprus you don't have many times when you need the seat heaters so removal of the fuse might be the best option, even if it disables the fronts as well. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
CarlW Member Since: 15 Jan 2008 Location: Lanarkshire Posts: 22 ![]() ![]() ![]() |
I've just checked mine and they default to 'off' each time the ignition is switched off, the front seats wont even switch on without the engine running. |
